2014-08-28 | Regenerate all preinstall.am files. | Joel Sherrill | 1 | -6/+6 | |
Apparently, at some point automake output changed and these were not updated. | |||||
2014-08-28 | arm: Add tests which fail to build with C++ enabled. | Chris Johns | 2 | -0/+8 | |
2014-08-27 | lpc40xx_ea_rom_int-testsuite.tcfg: New file | Joel Sherrill | 1 | -0/+7 | |
2014-08-20 | lpc24xx/lpc17xx: lpc24xx_pin_set_function() keep LPC4088 W type pin in ↵ | Pavel Pisa | 1 | -1/+6 | |
digital mode for non-analog function. The problem wit incorrect switching of pins into analog mode manifestes on LPC4088 based board. LPC4088 implements pin P1.17 (ENET_MDIO) as new W type (digital pin with analog option). The pin was listed as D category on LPC1788 which does not have analog mode control bit. If analog option is not explicitly switched off on LPC4088 then the pin does not work as digital pin. Code tested on LPC1788 and no problems has been observed even that manual specifies the IOCON_ADMODE field as reserved and should be written as zero. But even RTEMS lpc24xx_gpio_config sets this bit unconditionally. Signed-off-by: Pavel Pisa <ppisa@pikron.com> | |||||
2014-08-12 | bsp/lpc24xx: Add LPC40XX variants | Sebastian Huber | 8 | -19/+99 | |
2014-07-16 | Add More Testsuite Configuration Files and Update Existing Ones | Joel Sherrill | 2 | -0/+11 | |
The first pass at building these was without networking enabled. This pass addresses that plus accounts for some new BSPs which needed testsuite.tcfg files and BSPs which could not link tests which had been added since the first pass. | |||||
2014-05-06 | multiple BSPs: Remove BSP_SMALL_MEMORY | Joel Sherrill | 1 | -4/+0 | |
2014-05-05 | testsuite: Add a per BSP test check for tests not to build. | Chris Johns | 6 | -0/+90 | |
Provide a file per BSP to list tests that do not build for a BSP. This change removes the BSP_SMALL_MEMORY hack from the code. That hack was a mistake. Provide configuration files for each BSP with tests that cannot build. | |||||
2014-03-21 | Change all references of rtems.com to rtems.org. | Chris Johns | 39 | -39/+39 | |
2014-03-14 | bsp/lpc24xx: Add LPC24XX_PIN_ETHERNET_POWER_DOWN | Pavel Pisa | 2 | -0/+15 | |
2014-03-14 | bsp/lpc24xx: Add lpc24xx_pin_get_first_index() | Sebastian Huber | 1 | -0/+10 | |
2014-02-19 | score: Add RTEMS_FATAL_SOURCE_BSP | Sebastian Huber | 2 | -23/+5 | |
Merge RTEMS_FATAL_SOURCE_BSP_GENERIC and RTEMS_FATAL_SOURCE_BSP_SPECIFIC into new fatal source RTEMS_FATAL_SOURCE_BSP. This makes it easier to figure out the code position given a fatal source and code. | |||||
2014-02-14 | score: Add CPU counter support | Sebastian Huber | 2 | -1/+11 | |
Add a CPU counter interface to allow access to a free-running counter. It is useful to measure short time intervals. This can be used for example to enable profiling of critical low-level functions. Add two busy wait functions rtems_counter_delay_ticks() and rtems_counter_delay_nanoseconds() implemented via the CPU counter. | |||||
2014-01-30 | bsp/lpc24xx: Fix compile error | Sebastian Huber | 1 | -1/+1 | |
2014-01-10 | bsp/lpc24xx: Add PL111 support | Sebastian Huber | 4 | -0/+165 | |
2014-01-10 | bsp/lpc24xx: Add register definition | Sebastian Huber | 1 | -1/+3 | |
2013-12-09 | doxygen: refactored doxygen in libbsp to illustrate new rule set | Daniel Ramirez | 1 | -1/+1 | |
2013-05-03 | bsps/arm: Move implementation to inline functions | Sebastian Huber | 2 | -1/+1 | |
2013-04-08 | bsp/lpc24xx: Fix register address | Sebastian Huber | 1 | -1/+2 | |
2013-03-08 | RTEMS: Delete ChangeLog files. | Gedare Bloom | 1 | -470/+0 | |
This commit deletes all RTEMS ChangeLog files. These files have been abandoned since converting to git version control. The historical data may be recovered by checking out any commit before this one. Most of the contents of these ChangeLog files can also be found in the git log. Two external ChangeLog files, ChangeLog.slac and ChangeLog.zlib, remain. | |||||
2013-02-11 | bsp/lpc24xx: Move UART probes to separate files | Sebastian Huber | 6 | -53/+130 | |
2013-01-07 | bsp/lpc24xx: Declare conditionally | Sebastian Huber | 1 | -0/+4 | |
2013-01-07 | bsp/lpc24xx: System reset after fatal conditions | Sebastian Huber | 1 | -1/+1 | |
2013-01-07 | bsp/lpc24xx: Request system reset for LPC17XX | Sebastian Huber | 1 | -4/+6 | |
2013-01-07 | bsp/lpc24xx: Add WWDT module defines | Sebastian Huber | 1 | -1/+21 | |
2013-01-07 | arm: Rename inline functions | Sebastian Huber | 1 | -2/+2 | |
Rename arm_status_irq_enable() to _ARMV4_Status_irq_enable() and arm_status_restore() to _ARMV4_Status_restore(). | |||||
2013-01-07 | arm: Move inline functions | Sebastian Huber | 1 | -0/+2 | |
2013-01-07 | arm: Rename arm_exc_interrupt() | Sebastian Huber | 1 | -1/+1 | |
Rename arm_exc_interrupt() to _ARMV4_Exception_interrupt(). | |||||
2013-01-07 | arm: Move prototypes to new file | Sebastian Huber | 1 | -0/+1 | |
Move bsp_interrupt_dispatch() and arm_exc_interrupt() prototypes to new file <rtems/score/armv4.h> since they have nothing to do with the CPU port. | |||||
2012-12-18 | bsps/arm: Add interface down support | Sebastian Huber | 1 | -0/+5 | |
2012-11-15 | bsps: Interrupt initialization error is fatal | Sebastian Huber | 1 | -3/+1 | |
2012-11-15 | score: Add RTEMS_FATAL_SOURCE_EXIT | Sebastian Huber | 1 | -10/+12 | |
Include <bsp/default-initial-extension.h> in all BSPs. Call rtems_fatal() with RTEMS_FATAL_SOURCE_EXIT as source and the exit() status code as fatal code in every bsp_cleanup(). Move previous bsp_cleanup() code into bsp_fatal_extension(). | |||||
2012-10-12 | bsps/arm: Add BSP_USB_OTG_TRANSCEIVER_I2C_ADDR | Sebastian Huber | 1 | -0/+3 | |
2012-10-12 | bsp/lpc24xx: Fix PCLK clock divider calculation | Sebastian Huber | 1 | -1/+1 | |
2012-10-12 | bsp/lpc24xx: Use 96MHz CCLK for LPC17XX EA BSP | Sebastian Huber | 1 | -1/+1 | |
This enables USB support by PLL0. | |||||
2012-10-12 | bsp/lpc24xx: Evaluate LPC17XX pin type | Sebastian Huber | 2 | -4/+20 | |
New pin type LPC17XX_PIN_TYPE_OPEN_DRAIN. | |||||
2012-10-12 | bsp/lpc24xx: Enable USB clock by PLL0 for LPC17XX | Sebastian Huber | 1 | -2/+11 | |
2012-10-12 | bsp/lpc24xx: Fix warnings | Sebastian Huber | 1 | -2/+2 | |
2012-10-11 | Use proper 3 line form of license text | Joel Sherrill | 4 | -8/+12 | |
2012-09-28 | bsps/arm: Add LPC_DMA_CHANNEL_COUNT | Sebastian Huber | 1 | -0/+4 | |
2012-08-20 | bsp/lpc24xx: Use USB RAM for fast data section | Sebastian Huber | 3 | -3/+6 | |
2012-08-06 | Revert "Add bspopts.h.in." | Gedare Bloom | 1 | -115/+0 | |
This reverts commit daffa606cc4a45d93c1f0f4fe365fde0fda6acbb. Conflicts: c/src/lib/libbsp/arm/lpc24xx/include/bspopts.h.in c/src/lib/libbsp/powerpc/mpc55xxevb/include/bspopts.h.in c/src/lib/libbsp/powerpc/qoriq/include/bspopts.h.in Manually deleted conflicting files. | |||||
2012-07-19 | Use http://www.rtems.org/bugzilla as bug-URL. | Ralf Corsépius | 1 | -1/+1 | |
2012-07-19 | Require automake-1.12.2. | Ralf Corsépius | 1 | -1/+1 | |
2012-07-19 | Require autoconf-2.69. | Ralf Corsépius | 1 | -1/+1 | |
2012-06-15 | bsp/lpc24xx: More flexible region configuration | Sebastian Huber | 3 | -46/+67 | |
2012-06-15 | bsp/lpc24xx: Fix timing for M29W320E70 | Sebastian Huber | 1 | -2/+2 | |
2012-06-15 | bsp/lpc24xx: Add lpc24xx_module_is_enabled() | Sebastian Huber | 2 | -0/+26 | |
2012-06-15 | bsp/lpc24xx: Ethernet support for EA LPC1788 board | Sebastian Huber | 1 | -1/+1 | |
2012-06-15 | bsp/lpc24xx: Ethernet support for LPC17XX | Sebastian Huber | 1 | -9/+26 | |
