output.
digital mode for non-analog function.
The problem wit incorrect switching of pins into analog mode manifestes
on LPC4088 based board.
LPC4088 implements pin P1.17 (ENET_MDIO) as new W type (digital pin
with analog option). The pin was listed as D category on LPC1788
which does not have analog mode control bit. If analog option is
not explicitly switched off on LPC4088 then the pin does not work
as digital pin.
Code tested on LPC1788 and no problems has been observed even that
manual specifies the IOCON_ADMODE field as reserved and should
be written as zero. But even RTEMS lpc24xx_gpio_config sets this
bit unconditionally.
Signed-off-by: Pavel Pisa <ppisa@pikron.com>
New pin type LPC17XX_PIN_TYPE_OPEN_DRAIN.
* include/lpc17xx.h: New file.
* Makefile.am, preinstall.am: Reflect change above. Update due to API
changes.
* configure.ac, console/console-config.c, include/bsp.h, include/io.h,
include/irq.h, include/lcd.h, include/lpc-clock-config.h,
include/lpc24xx.h, include/start-config.h, irq/irq-dispatch.c,
irq/irq.c, misc/bspidle.c, misc/io.c, misc/lcd.c, misc/restart.c,
misc/system-clocks.c, ssp/ssp.c, startup/bspreset.c,
startup/bspstart.c, startup/bspstarthooks.c,
startup/start-config-emc-dynamic.c, startup/start-config-emc-static.c,
startup/start-config-pinsel.c: Basic support for LPC17XX. New memory
configurations for W9825G2JB75I, IS42S32800B, and SST39VF3201.
* i2c/i2c-config.c: New file.
* include/lcd.h: Removed EMC definitions.
* misc/dma.c: Fixed initialization.
* include/i2c.h, include/io.h, include/lpc-ethernet-config.h,
include/lpc24xx.h, console/console-config.c, i2c/i2c.c, misc/io.c,
misc/lcd.c, startup/bspstart.c, startup/bspstarthooks.c: New pin
configuration API.
* Makefile.am, preinstall.am: Update.
* misc/restart.c: New file.
* Makefile.am: Reflect change from above.
* include/bsp.h: Declare bsp_restart().
* misc/timer.c: Fix typo.
* misc/timer.c: Include <rtems/btimer.h>.
* include/lcd.h, misc/lcd.c: New files.
* misc/io.c, include/io.h: Documentation, bug fixes, more
configurations.
* include/lpc24xx.h: Added DAC and I2S.
* Makefile.am, bsp_specs, preinstall.am, startup/bspstarthooks.c,
startup/linkcmds.lpc2362, startup/linkcmds.lpc23xx_tli800,
startup/linkcmds.lpc24xx_ea, startup/linkcmds.lpc24xx_ncs_ram,
startup/linkcmds.lpc24xx_ncs_rom_ext,
startup/linkcmds.lpc24xx_ncs_rom_int: Update due to linker command
file changes.
* misc/system-clocks.c: Use define instead of function call to allow
smaller delays.
* include/lpc24xx.h, misc/system-clocks.c: Removed superfluous include
of <bsp/utility.h>.
* misc/system-clocks.c: Fixed lpc24xx_micro_seconds_delay().
* include/lpc24xx.h, misc/dma-copy.c, misc/dma.c,
misc/system-clocks.c, ssp/ssp.c, startup/bspstarthooks.c: Removed
superfluous macros.
* misc/bspidle.c: Include bsp.h and fix prototype.
* Makefile.am, preinstall.am, include/bsp.h: Rename BSP specific idle
thread to bsp_idle_thread.
* misc/bspidle.c: New file.
* include/idle.h, misc/idle.c: Removed.
* Makefile.am, configure.ac, preinstall.am: Added BSP variants.
* console/console-config.c, clock/clock-config.c, ssp/ssp.c: Fixed
register settings. Cleanup.
* include/bsp.h: Added network defines and functions.
* include/lpc24xx.h: Added AHB and EMC defines. Fixed Ethernet status
sizes.
* include/system-clocks.h, misc/system-clocks.c: Added micro seconds
delay function that uses Timer 1. Changed PLL setup.
* network/network.c, startup/bspreset.c, startup/linkcmds.lpc2478,
startup/linkcmds.lpc2478_ncs, startup/linkcmds.lpc2478_ncs_ram: New
files.
* startup/bspstart.c: Added EMC initialization. Changes for ROM boot.
* Makefile.am, preinstall.am, include/lpc24xx.h, misc/system-clocks.c:
Move utility.h
