* make/custom/lpc24xx.inc: Flags for EABI tool chain.
* include/lpc24xx.h: Added ADC defines.
* make/custom/lpc24xx.inc: Workaround for GCC bug 49641.
* make/custom/lpc24xx.inc: Workaround for GCC bug 38644.
* make/custom/lpc24xx.inc: Use VFP floating point model.
* configure.ac: Add RTEMS_BSP_LINKCMDS.
* make/custom/lpc24xx.inc: Remove LDFLAGS.
* make/custom/lpc24xx_ea.cfg: Remove LPC24XX_LINKCMDS.
* make/custom/lpc24xx_ncs_ram.cfg: Remove LPC24XX_LINKCMDS.
* make/custom/lpc24xx_ncs_rom_ext.cfg: Remove LPC24XX_LINKCMDS.
* make/custom/lpc24xx_ncs_rom_int.cfg: Remove LPC24XX_LINKCMDS.
* startup/linkcmds: Remove.
* Makefile.am: Rework linkcmds handling.
* make/custom/lpc24xx.inc: Remove RTEMS_BSP_FAMILY.
* make/custom/lpc24xx.inc: New (Renamed from lpc24xx.cfg).
* make/custom/lpc24xx.cfg: Removed.
* make/custom/lpc24xx_ea.cfg, lpc24xx_ncs_ram.cfg,
make/custom/lpc24xx_ncs_rom_ext.cfg,
Include make/custom/lpc24xx.inc.
