* | bsps: Improve interrupt vector enable/disable API | Sebastian Huber | 2017-06-20 | 1 | -6/+4 |
| | | | | | | Change bsp_interrupt_vector_enable() and bsp_interrupt_vector_disable() to not return a status code. Add bsp_interrupt_assert() and use it to validate the vector number in the vector enable/disable implementations. | ||||
* | Change all references of rtems.com to rtems.org. | Chris Johns | 2014-03-21 | 2 | -2/+2 |
* | arm: Rename inline functions | Sebastian Huber | 2013-01-07 | 1 | -2/+2 |
| | | | | | Rename arm_status_irq_enable() to _ARMV4_Status_irq_enable() and arm_status_restore() to _ARMV4_Status_restore(). | ||||
* | arm: Move inline functions | Sebastian Huber | 2013-01-07 | 1 | -0/+2 |
* | arm: Rename arm_exc_interrupt() | Sebastian Huber | 2013-01-07 | 1 | -1/+1 |
| | | | | Rename arm_exc_interrupt() to _ARMV4_Exception_interrupt(). | ||||
* | arm: Move prototypes to new file | Sebastian Huber | 2013-01-07 | 1 | -0/+1 |
| | | | | | | Move bsp_interrupt_dispatch() and arm_exc_interrupt() prototypes to new file <rtems/score/armv4.h> since they have nothing to do with the CPU port. | ||||
* | bsps: Shared ARMv7-M interrupt support | Sebastian Huber | 2012-03-24 | 2 | -79/+47 |
* | bsps: Add shared default IRQ handler | Sebastian Huber | 2012-03-24 | 1 | -5/+0 |
* | Support for NXP LPC1700 family | Sebastian Huber | 2012-02-11 | 2 | -2/+36 |
* | 2011-11-08 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2011-11-08 | 2 | -37/+59 |
| | | | | | | | | | | | | | | | * include/lpc17xx.h: New file. * Makefile.am, preinstall.am: Reflect change above. Update due to API changes. * configure.ac, console/console-config.c, include/bsp.h, include/io.h, include/irq.h, include/lcd.h, include/lpc-clock-config.h, include/lpc24xx.h, include/start-config.h, irq/irq-dispatch.c, irq/irq.c, misc/bspidle.c, misc/io.c, misc/lcd.c, misc/restart.c, misc/system-clocks.c, ssp/ssp.c, startup/bspreset.c, startup/bspstart.c, startup/bspstarthooks.c, startup/start-config-emc-dynamic.c, startup/start-config-emc-static.c, startup/start-config-pinsel.c: Basic support for LPC17XX. New memory configurations for W9825G2JB75I, IS42S32800B, and SST39VF3201. | ||||
* | 2011-08-08 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2011-08-08 | 2 | -26/+53 |
| | | | | | | * irq/irq-dispatch.c: New file. * irq/irq.c: Moved bsp_interrupt_dispatch() to new file. * Makefile.am: Reflect change from above. | ||||
* | 2010-04-30 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2010-04-30 | 1 | -6/+2 |
| | | | | | | * include/irq-config.h: Removed file. * Makefile.am, preinstall.am: Reflect change above. * irq/irq.c: Removed superfluous parameter checks. | ||||
* | Changes throughout | Thomas Doerfler | 2010-04-09 | 1 | -2/+4 |
* | add support for LPC32xx | Thomas Doerfler | 2009-12-15 | 1 | -19/+16 |
* | Changes throughout. | Thomas Doerfler | 2009-09-18 | 1 | -1/+1 |
* | ARM bsp maintenance | Thomas Doerfler | 2009-07-17 | 1 | -9/+47 |
* | lpc24xx: new BSP | Thomas Doerfler | 2008-09-22 | 1 | -0/+90 |
