* | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 2012-05-11 | 1 | -4/+0 |
* | 2011-03-16 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2011-03-16 | 1 | -0/+5 |
| | | | | * README: Add example mkimage command. | ||||
* | Typo. | Sebastian Huber | 2010-06-23 | 1 | -2/+2 |
* | 2010-06-23 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2010-06-23 | 1 | -0/+5 |
| | | | | | | | | * make/custom/lpc23xx_tli800.cfg, startup/linkcmds.lpc23xx_tli800: New files. * Makefile.am, configure.ac: Reflect changes above. * startup/linkcmds.lpc2362: Typos. * README: Documentation. | ||||
* | renamed lpc24xx BSPs, reorganized linkcmds | Thomas Doerfler | 2009-10-05 | 1 | -4/+2 |
* | ARM bsp maintenance | Thomas Doerfler | 2009-07-17 | 1 | -0/+3 |
* | * README: Added NCS. | Thomas Doerfler | 2009-02-27 | 1 | -0/+32 |
| | | | | | | | | | | | | | | | * Makefile.am, configure.ac, preinstall.am: Added BSP variants. * console/console-config.c, clock/clock-config.c, ssp/ssp.c: Fixed register settings. Cleanup. * include/bsp.h: Added network defines and functions. * include/lpc24xx.h: Added AHB and EMC defines. Fixed Ethernet status sizes. * include/system-clocks.h, misc/system-clocks.c: Added micro seconds delay function that uses Timer 1. Changed PLL setup. * network/network.c, startup/bspreset.c, startup/linkcmds.lpc2478, startup/linkcmds.lpc2478_ncs, startup/linkcmds.lpc2478_ncs_ram: New files. * startup/bspstart.c: Added EMC initialization. Changes for ROM boot. | ||||
* | added SSP support files, fixed some typos | Thomas Doerfler | 2008-09-30 | 1 | -0/+1 |
* | 2008-09-23 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2008-09-23 | 1 | -0/+6 |
| | | | | * README: Add URL. | ||||
* | lpc24xx: new BSP | Thomas Doerfler | 2008-09-22 | 1 | -0/+6 |
