* | 2009-02-17 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-02-17 | 1 | -2/+3 |
| | | | | * Makefile.am: Fix breakage introduced in 2009-02-13 changes. | ||||
* | 2009-02-13 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-02-13 | 1 | -12/+13 |
| | | | | * Makefile.am, preinstall.am: Use stub tm27.h. | ||||
* | 2008-09-30 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-09-30 | 1 | -0/+3 |
| | | | | * Makefile.am, preinstall.am: Add timer driver stub. | ||||
* | added SSP support files, fixed some typos | Thomas Doerfler | 2008-09-30 | 1 | -15/+26 |
* | 2008-09-30 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-09-30 | 1 | -1/+1 |
| | | | | | * clock/clock-config.c: include "../../../shared/clockdrv_shell.h". * Makefile.am: Reflect changes above. | ||||
* | 2008-09-29 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-09-29 | 1 | -4/+3 |
| | | | | | * Makefile.am: Eliminate bsp.am. Build startup files as side-effect of building libbspstart.a, using automake-rules. | ||||
* | 2008-09-29 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-09-29 | 1 | -15/+15 |
| | | | | * Makefile.am: Eliminate *_SOURCES. | ||||
* | 2008-09-29 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-09-29 | 1 | -4/+2 |
| | | | | | * Makefile.am: Move noinst_LIBRARIES = libbsp.a before its components. | ||||
* | 2008-09-26 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-09-26 | 1 | -2/+3 |
| | | | | * Makefile.am: Cleanup ../../shared/include/bootcard.h handling. | ||||
* | 2008-09-24 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-09-24 | 1 | -2/+0 |
| | | | | * Makefile.am: Eliminates libcpudir. | ||||
* | 2008-09-24 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-09-24 | 1 | -16/+0 |
| | | | | * Makefile.am: Remove NETWORKING (Sources are missing). | ||||
* | Remove duplicate bsp_specs. | Ralf Corsepius | 2008-09-24 | 1 | -3/+2 |
* | 2008-09-24 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-09-24 | 1 | -0/+1 |
| | | | | * Makefile.am: Add DISTCLEANFILES = include/bspopts.h. | ||||
* | 2008-09-24 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-09-24 | 1 | -0/+2 |
| | | | | * Makefile.am: Add bsp_specs. | ||||
* | 2008-09-23 Sebastian Huber <sebastian.huber@embedded-brains.de> | Joel Sherrill | 2008-09-23 | 1 | -1/+2 |
| | | | | | * Makefile.am, preinstall.am, include/lpc24xx.h, misc/system-clocks.c: Move utility.h | ||||
* | 2008-09-22 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-09-22 | 1 | -0/+1 |
| | | | | | | | | * Makefile.am, startup/bspstart.c: Use standardized bsp_cleanup() which can optionally print a message, poll for user to press key, and call bsp_reset(). Using this eliminates the various bsp_cleanup() implementations which had their own implementation and variety of string constants. | ||||
* | lpc24xx: new BSP | Thomas Doerfler | 2008-09-22 | 1 | -0/+114 |
