* Makefile.am: Fix breakage introduced in 2009-02-13 changes.
* Makefile.am, preinstall.am: Use stub tm27.h.
* configure.ac: Add RTEMS_BSPOPTS(LPC24XX_OSCILLATOR_RTC).
Add RTEMS_BSPOPTS(LPC24XX_OSCILLATOR_MAIN).
* include/bsp.h: #include <bspopts.h>.
* misc/system-clocks.c: Receive LPC24XX_OSCILLATOR_RTC,
LPC24XX_OSCILLATOR_MAIN through bspopts.h.
* bsp_specs: Move -e start from *link to *startfile to avoid warning
for undefined entry symbol when linking relocatables with binutils
2.19.
* Makefile.am, preinstall.am: Add timer driver stub.
* clock/clock-config.c: include "../../../shared/clockdrv_shell.h".
* Makefile.am: Eliminate bsp.am. Build startup files as side-effect
of building libbspstart.a, using automake-rules.
* Makefile.am: Eliminate *_SOURCES.
* Makefile.am: Move noinst_LIBRARIES = libbsp.a before its
components.
* Makefile.am: Cleanup ../../shared/include/bootcard.h handling.
* preinstall.am: Regenerated.
* Makefile.am: Eliminates libcpudir.
* Makefile.am: Remove NETWORKING (Sources are missing).
* Makefile.am: Add DISTCLEANFILES = include/bspopts.h.
* Makefile.am: Add bsp_specs.
PR 1322/bsps
* include/bspopts.h.in: Remove.
* configure.ac, include/bspopts.h.in: Make letting boot_card() handle
work area allocation mandatory. Rename
RTEMS_BSP_BOOTCARD_HANDLES_RAM_ALLOCATION to BSP_BOOTCARD_OPTIONS.
* README: Add URL.
* Makefile.am, preinstall.am, include/lpc24xx.h, misc/system-clocks.c:
Move utility.h
* Makefile.am, startup/bspstart.c: Use standardized bsp_cleanup() which
can optionally print a message, poll for user to press key, and call
bsp_reset(). Using this eliminates the various bsp_cleanup()
implementations which had their own implementation and variety of
string constants.
* .cvsignore, include/bspopts.h.in: New files.
