* | Multiple bsp_specs: Change *(old_endfile) to %(old_endfile) | Joel Sherrill | 2015-05-21 | 1 | -1/+1 |
| | | | | | | Fix typo. closes 2345. | ||||
* | lm3s3749-testsuite.tcfg: Add cdtest | Joel Sherrill | 2015-04-23 | 1 | -0/+1 |
* | arm/lm3s69xx/make/custom/lm4f120-testsuite.tcfg: Add tmfine01 | Joel Sherrill | 2015-03-17 | 1 | -0/+1 |
* | Add fsscandir01 variants as needed to more BSPs testsuite configuration | Joel Sherrill | 2015-03-06 | 3 | -0/+4 |
* | lm3s69xx/.../lm3s6965-testsuite.tcfg: Add more tests | Joel Sherrill | 2015-01-23 | 1 | -0/+1 |
* | lm3s69xx/.../lm3s3749-testsuite.tcfg: Add more tests | Joel Sherrill | 2015-01-23 | 1 | -0/+2 |
* | Update bug report URL | Sebastian Huber | 2014-12-05 | 1 | -1/+1 |
* | bsps/arm: Add .nocache section | Sebastian Huber | 2014-11-27 | 4 | -0/+8 |
| | | | | | This section can be use to provide a cache coherent memory area via rtems_cache_coherent_add_area(). | ||||
* | lm3s3749-testsuite.tcfg: Add dl02 | Joel Sherrill | 2014-11-05 | 1 | -0/+1 |
* | lm3s3749-testsuite.tcfg: Add dl01 | Joel Sherrill | 2014-11-04 | 1 | -0/+1 |
* | arm/lm3s69xx/startup/bspstart.c: Add include of <bsp/bootcard.h> to fix warning | Joel Sherrill | 2014-10-09 | 1 | -0/+5 |
* | bsps: Fix build error | Sebastian Huber | 2014-09-18 | 2 | -5/+0 |
| | | | | Fix build error introduced in f535fe5311978af53635c2da8e5cb10ef9d78802. | ||||
* | lm3s3749-testsuite.tcfg: Add tests which do not link with debug enabled | Joel Sherrill | 2014-09-04 | 1 | -0/+3 |
* | lm3s69xx/.../bspreset.c: Eliminate warning for set not used variable | Joel Sherrill | 2014-09-04 | 1 | -0/+1 |
* | Regenerate all preinstall.am files. | Joel Sherrill | 2014-08-28 | 1 | -6/+6 |
| | | | | | Apparently, at some point automake output changed and these were not updated. | ||||
* | arm: Add tests which fail to build with C++ enabled. | Chris Johns | 2014-08-28 | 2 | -0/+6 |
* | arm/lm3s3749: Add tests that do not fit. | Chris Johns | 2014-08-27 | 1 | -0/+3 |
| | | | | You need --enable-c++ for the c++ tests. | ||||
* | Add More Testsuite Configuration Files and Update Existing Ones | Joel Sherrill | 2014-07-16 | 3 | -0/+10 |
| | | | | | | | The first pass at building these was without networking enabled. This pass addresses that plus accounts for some new BSPs which needed testsuite.tcfg files and BSPs which could not link tests which had been added since the first pass. | ||||
* | lm3s6965-testsuite.cfg: Add pppd. | Martin Galvan | 2014-06-10 | 1 | -0/+1 |
| | | | | | | When trying to compile RTEMS for the Stellaris LM3S6965 board, I had an issue of pppd.exe's .rodata section being too big to fit in the board's memory image (region 'ROM_INT' overflowed). | ||||
* | multiple BSPs: Remove BSP_SMALL_MEMORY | Joel Sherrill | 2014-05-06 | 1 | -4/+0 |
* | testsuite: Add a per BSP test check for tests not to build. | Chris Johns | 2014-05-05 | 3 | -0/+69 |
| | | | | | | | | Provide a file per BSP to list tests that do not build for a BSP. This change removes the BSP_SMALL_MEMORY hack from the code. That hack was a mistake. Provide configuration files for each BSP with tests that cannot build. | ||||
* | Change all references of rtems.com to rtems.org. | Chris Johns | 2014-03-21 | 15 | -15/+15 |
* | score: Add CPU counter support | Sebastian Huber | 2014-02-14 | 1 | -0/+2 |
| | | | | | | | | | Add a CPU counter interface to allow access to a free-running counter. It is useful to measure short time intervals. This can be used for example to enable profiling of critical low-level functions. Add two busy wait functions rtems_counter_delay_ticks() and rtems_counter_delay_nanoseconds() implemented via the CPU counter. | ||||
* | arm_lm3s69xx: improve doxygen | Toma Radu | 2013-12-17 | 7 | -0/+112 |
| | | | | Add doxygen to the header files in the arm/lm3s69xx/include directory. | ||||
* | bsp/lm4f120: new BSP to support TI LM4F120 XL LaunchPad board | Karel Gardas | 2013-09-02 | 8 | -11/+121 |
* | bsp/lm3s69xx: add macros for UART CTS/RTS pin configuration | Karel Gardas | 2013-08-14 | 1 | -0/+28 |
* | Use $(EXEEXT) [defaults to "exe"] to generate binaries | Nick Withers | 2013-08-09 | 1 | -1/+1 |
* | bsp/lm3s69xx: Typos | Sebastian Huber | 2013-06-03 | 3 | -5/+5 |
* | bsp/lm3s69xx: Fix initialization value | Sebastian Huber | 2013-05-06 | 1 | -1/+1 |
* | bsp/lm3s69xx: Use interrupts for UART receive | Eugeniy Meshcheryakov | 2013-05-06 | 1 | -12/+47 |
| | | | | This makes continuous UART polling unnecessary. | ||||
* | bsp/lm3s69xx: More access macros for UART data register | Eugeniy Meshcheryakov | 2013-05-06 | 1 | -0/+2 |
| | | | | | Add mask for receive error bits and getter macro for the data field. | ||||
* | bsps/arm: Move implementation to inline functions | Sebastian Huber | 2013-05-03 | 2 | -1/+1 |
* | bsp/lm3s69xx: New BSP variants | Eugeniy Meshcheryakov | 2013-04-26 | 22 | -136/+1286 |
| | | | | Add support for LM3S3749. | ||||
* | RTEMS: Delete ChangeLog files. | Gedare Bloom | 2013-03-08 | 1 | -19/+0 |
| | | | | | | | | | This commit deletes all RTEMS ChangeLog files. These files have been abandoned since converting to git version control. The historical data may be recovered by checking out any commit before this one. Most of the contents of these ChangeLog files can also be found in the git log. Two external ChangeLog files, ChangeLog.slac and ChangeLog.zlib, remain. | ||||
* | libchip/serial: Add const qualifier | Sebastian Huber | 2013-02-11 | 2 | -2/+2 |
* | bsps: Interrupt initialization error is fatal | Sebastian Huber | 2012-11-15 | 1 | -3/+1 |
* | score: Add RTEMS_FATAL_SOURCE_EXIT | Sebastian Huber | 2012-11-15 | 1 | -9/+11 |
| | | | | | | | Include <bsp/default-initial-extension.h> in all BSPs. Call rtems_fatal() with RTEMS_FATAL_SOURCE_EXIT as source and the exit() status code as fatal code in every bsp_cleanup(). Move previous bsp_cleanup() code into bsp_fatal_extension(). | ||||
* | Revert "Add bspopts.h.in." | Gedare Bloom | 2012-08-06 | 1 | -49/+0 |
| | | | | | | | | | | | | This reverts commit daffa606cc4a45d93c1f0f4fe365fde0fda6acbb. Conflicts: c/src/lib/libbsp/arm/lpc24xx/include/bspopts.h.in c/src/lib/libbsp/powerpc/mpc55xxevb/include/bspopts.h.in c/src/lib/libbsp/powerpc/qoriq/include/bspopts.h.in Manually deleted conflicting files. | ||||
* | Use http://www.rtems.org/bugzilla as bug-URL. | Ralf Corsépius | 2012-07-19 | 1 | -1/+1 |
* | Require automake-1.12.2. | Ralf Corsépius | 2012-07-19 | 1 | -1/+1 |
* | Require autoconf-2.69. | Ralf Corsépius | 2012-07-19 | 1 | -1/+1 |
* | bsps/arm: Rename linkcmds.armv7 to linkcmds.armv7m | Sebastian Huber | 2012-06-15 | 1 | -1/+1 |
* | bsps: Replace NIRVANA region | Sebastian Huber | 2012-06-12 | 1 | -1/+0 |
| | | | | | Replace the "NIRVANA" region with the more verbose "UNEXPECTED_SECTIONS" region. Move the region definition into the "linkcmds.base" files. | ||||
* | Add bspopts.h.in. | Ralf Corsépius | 2012-05-24 | 1 | -0/+49 |
* | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 2012-05-11 | 5 | -10/+0 |
* | bsps/arm: Add BSP_ARMV7M_SYSTICK_PRIORITY | Sebastian Huber | 2012-04-07 | 1 | -0/+2 |
* | bsps/arm: Add BSP_ARMV7M_IRQ_PRIORITY_DEFAULT | Sebastian Huber | 2012-04-07 | 1 | -1/+3 |
* | bsp/lm3s69xx: Reflect new Qemu patch | Sebastian Huber | 2012-03-24 | 1 | -6/+1 |
* | bsps: Shared ARMv7-M interrupt support | Sebastian Huber | 2012-03-24 | 3 | -48/+7 |
* | bsps: Add shared default IRQ handler | Sebastian Huber | 2012-03-24 | 2 | -7/+3 |
