* | bsps/arm: Add .nocache section | Sebastian Huber | 2014-11-27 | 4 | -0/+8 |
| | | | | | This section can be use to provide a cache coherent memory area via rtems_cache_coherent_add_area(). | ||||
* | arm/lm3s69xx/startup/bspstart.c: Add include of <bsp/bootcard.h> to fix warning | Joel Sherrill | 2014-10-09 | 1 | -0/+5 |
* | lm3s69xx/.../bspreset.c: Eliminate warning for set not used variable | Joel Sherrill | 2014-09-04 | 1 | -0/+1 |
* | Change all references of rtems.com to rtems.org. | Chris Johns | 2014-03-21 | 5 | -5/+5 |
* | bsp/lm4f120: new BSP to support TI LM4F120 XL LaunchPad board | Karel Gardas | 2013-09-02 | 3 | -7/+89 |
* | bsp/lm3s69xx: Typos | Sebastian Huber | 2013-06-03 | 1 | -2/+2 |
* | bsps/arm: Move implementation to inline functions | Sebastian Huber | 2013-05-03 | 1 | -0/+1 |
* | bsp/lm3s69xx: New BSP variants | Eugeniy Meshcheryakov | 2013-04-26 | 7 | -13/+406 |
| | | | | Add support for LM3S3749. | ||||
* | bsps: Interrupt initialization error is fatal | Sebastian Huber | 2012-11-15 | 1 | -3/+1 |
* | bsps/arm: Rename linkcmds.armv7 to linkcmds.armv7m | Sebastian Huber | 2012-06-15 | 1 | -1/+1 |
* | bsps: Replace NIRVANA region | Sebastian Huber | 2012-06-12 | 1 | -1/+0 |
| | | | | | Replace the "NIRVANA" region with the more verbose "UNEXPECTED_SECTIONS" region. Move the region definition into the "linkcmds.base" files. | ||||
* | bsp/lm3s69xx: Use shared start.S | Sebastian Huber | 2012-03-24 | 1 | -63/+6 |
* | 2011-09-24 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2011-09-24 | 4 | -0/+170 |
* 0001-Fixed-interrupt-handling-for-ARMv7M.patch, 0002-Fixed-system-handler-priority-register-access.patch, 0003-Disable-priority_mask-unused-for-NVIC.patch, 0004-Typo.patch, 0005-Evil-hack-for-BASEPRI-BASEPRI_MAX.patch, 0006-Evil-hack-to-increase-the-RAM-size.patch, bsp_specs, ChangeLog, clock/clock-config.c, configure.ac, console/console-config.c, console/uart.c, .cvsignore, include/bsp.h, include/.cvsignore, include/irq.h, include/lm3s69xx.h, include/uart.h, irq/irq.c, make/custom/lm3s6965.cfg, make/custom/lm3s69xx.inc, Makefile.am, README, start/start.S, startup/bspreset.c, startup/bspstart.c, startup/bspstarthook.c, startup/linkcmds.lm3s6965, timer/timer.c: New files. |
