* | bsp/lm3s69xx: Typos | Sebastian Huber | 2013-06-03 | 1 | -1/+1 |
* | bsp/lm3s69xx: New BSP variants | Eugeniy Meshcheryakov | 2013-04-26 | 1 | -4/+9 |
| | | | | Add support for LM3S3749. | ||||
* | 2011-11-07 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2011-11-07 | 1 | -8/+7 |
| | | | | | PR 1951/bsps * Makefile.am, console/console-config.c: Update due to API changes. | ||||
* | 2011-09-24 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2011-09-24 | 1 | -0/+79 |
* 0001-Fixed-interrupt-handling-for-ARMv7M.patch, 0002-Fixed-system-handler-priority-register-access.patch, 0003-Disable-priority_mask-unused-for-NVIC.patch, 0004-Typo.patch, 0005-Evil-hack-for-BASEPRI-BASEPRI_MAX.patch, 0006-Evil-hack-to-increase-the-RAM-size.patch, bsp_specs, ChangeLog, clock/clock-config.c, configure.ac, console/console-config.c, console/uart.c, .cvsignore, include/bsp.h, include/.cvsignore, include/irq.h, include/lm3s69xx.h, include/uart.h, irq/irq.c, make/custom/lm3s6965.cfg, make/custom/lm3s69xx.inc, Makefile.am, README, start/start.S, startup/bspreset.c, startup/bspstart.c, startup/bspstarthook.c, startup/linkcmds.lm3s6965, timer/timer.c: New files. |
