* | bsps: Fix build error | Sebastian Huber | 2014-09-18 | 1 | -1/+0 |
| | | | | Fix build error introduced in f535fe5311978af53635c2da8e5cb10ef9d78802. | ||||
* | score: Add CPU counter support | Sebastian Huber | 2014-02-14 | 1 | -0/+2 |
| | | | | | | | | | Add a CPU counter interface to allow access to a free-running counter. It is useful to measure short time intervals. This can be used for example to enable profiling of critical low-level functions. Add two busy wait functions rtems_counter_delay_ticks() and rtems_counter_delay_nanoseconds() implemented via the CPU counter. | ||||
* | bsps/arm: Move implementation to inline functions | Sebastian Huber | 2013-05-03 | 1 | -1/+0 |
* | bsp/lm3s69xx: New BSP variants | Eugeniy Meshcheryakov | 2013-04-26 | 1 | -1/+9 |
| | | | | Add support for LM3S3749. | ||||
* | bsps: Shared ARMv7-M interrupt support | Sebastian Huber | 2012-03-24 | 1 | -1/+3 |
* | bsps: Add shared default IRQ handler | Sebastian Huber | 2012-03-24 | 1 | -2/+3 |
* | bsp/lm3s69xx: Format | Sebastian Huber | 2012-03-24 | 1 | -46/+40 |
* | bsp/lm3s69xx: Use shared timer stub driver | Sebastian Huber | 2012-03-24 | 1 | -1/+1 |
* | bsp/lm3s69xx: Use shared start.S | Sebastian Huber | 2012-03-24 | 1 | -4/+6 |
* | bsps: Shared ARMv7-M clock driver | Sebastian Huber | 2012-03-24 | 1 | -2/+2 |
* | 2011-11-07 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2011-11-07 | 1 | -3/+7 |
| | | | | | PR 1951/bsps * Makefile.am, console/console-config.c: Update due to API changes. | ||||
* | 2011-09-24 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2011-09-24 | 1 | -0/+114 |
* 0001-Fixed-interrupt-handling-for-ARMv7M.patch, 0002-Fixed-system-handler-priority-register-access.patch, 0003-Disable-priority_mask-unused-for-NVIC.patch, 0004-Typo.patch, 0005-Evil-hack-for-BASEPRI-BASEPRI_MAX.patch, 0006-Evil-hack-to-increase-the-RAM-size.patch, bsp_specs, ChangeLog, clock/clock-config.c, configure.ac, console/console-config.c, console/uart.c, .cvsignore, include/bsp.h, include/.cvsignore, include/irq.h, include/lm3s69xx.h, include/uart.h, irq/irq.c, make/custom/lm3s6965.cfg, make/custom/lm3s69xx.inc, Makefile.am, README, start/start.S, startup/bspreset.c, startup/bspstart.c, startup/bspstarthook.c, startup/linkcmds.lm3s6965, timer/timer.c: New files. |
