* | bsps: Use CPPASCOMPILE for startfile | Sebastian Huber | 2018-01-02 | 1 | -5/+4 | |
| | | | | Update #3254. | |||||
* | bsps: Add EXTRA_DIST to all BSP Makefile.am | Sebastian Huber | 2018-01-02 | 1 | -0/+1 | |
| | | | | | | | | | | This makes it possible to easily use EXTRA_DIST += foobar in fragments. Update #3254. | |||||
* | bsps: Include bsp.am in all BSP Makefile.am | Sebastian Huber | 2018-01-02 | 1 | -0/+1 | |
* | ARM BSPs: Simplify bsp_specs | Joel Sherrill | 2017-12-19 | 1 | -5/+1 | |
| | | | | Updates #3520. | |||||
* | bsps/arm: Fix move <libcpu/arm-cp15.h> to cpukit | Sebastian Huber | 2017-12-15 | 2 | -12/+0 | |
* | arm/*/bsp_specs: Remove extra space to increase consistency | Joel Sherrill | 2017-11-29 | 1 | -1/+1 | |
* | libbsp/*/*/configure.ac: Remove references to bsp_specs in AC_CONFIG_SRCDIR | Joel Sherrill | 2017-11-27 | 1 | -1/+1 | |
| | | | | Updates #3250. | |||||
* | Remove coverhd.h | Sebastian Huber | 2017-11-24 | 2 | -6/+1 | |
| | | | | | | | This header file contained timing overhead values which are hard to maintain. Update #3254. | |||||
* | bsps: Simplify RTEMS_BSP_CLEANUP_OPTIONS | Sebastian Huber | 2017-11-22 | 1 | -1/+1 | |
| | | | | | | | | | Remove BSP-specific defaults for RTEMS_BSP_CLEANUP_OPTIONS to simplify the BSP configuration and documentation. Change defaults to: BSP_PRESS_KEY_FOR_RESET=0 BSP_RESET_BOARD_AT_EXIT=1 BSP_PRINT_EXCEPTION_CONTEXT=1 | |||||
* | bsps: Add default getentropy() implementation | Sebastian Huber | 2017-11-22 | 1 | -0/+1 | |
| | | | | | Update #3239. Close #3249. | |||||
* | bsp/imx: Add UART baud change | Sebastian Huber | 2017-11-08 | 1 | -0/+19 | |
| | | | | Update #3090. | |||||
* | bsp/imx: Better utilize UART transmit FIFO | Sebastian Huber | 2017-11-08 | 1 | -7/+18 | |
* | bsp/imx: More robust and faster bsp_reset() | Sebastian Huber | 2017-11-02 | 1 | -3/+3 | |
* | bsp/imx: Drain console before reset | Sebastian Huber | 2017-11-02 | 3 | -1/+18 | |
* | bsp/imx: Implement bsp_reset() | Sebastian Huber | 2017-11-02 | 4 | -1/+79 | |
* | bsp/imx: Add SPI bus driver | Sebastian Huber | 2017-10-06 | 3 | -0/+463 | |
* | bsp/imx: Add imx_iomux_configure_pins() | Sebastian Huber | 2017-10-06 | 4 | -0/+107 | |
* | bsp/imx: Import iomux from FreeBSD | Sebastian Huber | 2017-10-06 | 3 | -0/+440 | |
* | bsp/imx: Fix I2C registration with path | Sebastian Huber | 2017-10-06 | 1 | -4/+9 | |
* | bsp/imx: Add I2C bus driver | Sebastian Huber | 2017-10-02 | 3 | -0/+451 | |
* | bsp/imx: Fix I2C register header | Sebastian Huber | 2017-10-02 | 1 | -27/+31 | |
* | bsp/imx: Add imx_get_reg_of_node() | Sebastian Huber | 2017-10-02 | 3 | -9/+16 | |
* | bsp/imx: Add imx_get_irq_of_node() | Sebastian Huber | 2017-10-02 | 3 | -14/+29 | |
* | bsp/imx: Add nocache section | Sebastian Huber | 2017-09-27 | 3 | -4/+10 | |
* | bsp/imx: Provide a default console | Sebastian Huber | 2017-09-26 | 1 | -1/+1 | |
* | bsp/imx: Add register headers | Sebastian Huber | 2017-09-26 | 4 | -0/+171 | |
* | bsps: Generalize bsp_fdt_map_intr() | Sebastian Huber | 2017-09-22 | 2 | -3/+5 | |
| | | | | | | | Pass all interrupt cells to bsp_fdt_map_intr() since some platforms use an array to describe an interrupt. Update #3090. | |||||
* | bsp/imx: Add SMP support | Sebastian Huber | 2017-09-22 | 3 | -16/+32 | |
* | bsp/imx: Add register headers | Sebastian Huber | 2017-09-22 | 4 | -0/+276 | |
* | Simplify and unify BSP_output_char | Sebastian Huber | 2017-09-12 | 1 | -9/+1 | |
| | | | | | | | | The BSP_output_char should output a char and not mingle with high level processing, e.g. '\n' to '\r\n' translation. Move this translation to rtems_putc(). Remove it from all the BSP_output_char implementations. Close #3122. | |||||
* | bsp/imx: Fix UART interrupt | Sebastian Huber | 2017-08-04 | 1 | -0/+2 | |
* | bsp/imx: New BSP | Sebastian Huber | 2017-08-04 | 17 | -0/+1325 | |
Update #3090. |
