* bsp_specs, start/start.S, startup/linkcmds: Use linker command base
file.
* rtl8019/rtl8019.c: Fix typo.
* rtl8019/rtl8019.c: Fixed interrupt handler.
* Makefile.am, preinstall.am: Added generic interrupt support modules.
* include/bsp.h: Define BSP_FEATURE_IRQ_EXTENSION.
* startup/bspstart.c, rtl8019/rtl8019.c: Interrupt support changes.
* csb336/make/custom/csb336.cfg,
csb337/make/custom/csb337.cfg, edb7312/make/custom/edb7312.cfg,
gba/make/custom/gba.cfg, gdbarmsim/make/custom/arm920.cfg,
gp32/make/custom/gp32.cfg, gumstix/make/custom/gumstix.cfg,
lpc32xx/make/custom/lpc32xx_phycore.cfg, nds/make/custom/nds.cfg,
rtl22xx/make/custom/rtl22xx.cfg, smdk2410/make/custom/smdk2410.cfg:
Use VFP floating point model.
* start/start.S: Verify boot_card() is passed a NULL.
* make/custom/gumstix.cfg: Remove RTEMS_BSP_FAMILY.
* make/custom/gumstix.cfg: New (relocated from /make/custom).
* configure.ac: Resolve confusion with Ralf's patch.
* configure.ac, fb/fb.c, include/bsp.h: updates made for porting to
Nano-X and make testing easyer
* configure.ac: Remove RTEMS_BSP_BOOTCARD_OPTIONS.
* configure.ac: Add default value.
* fb/fb.c: Register correct device name.
* startup/bspstart.c: Fix warnings.
* include/bsp.h: Eliminate BSPs defining NUMBER_OF_TERMIOS_PORTS.
Should be automatically handled by confdefs.h or the application.
* Makefile.am: Add fb/fb.c add rtl8019 Ethernet card support
* preinstall.am: Install skyeye_fb.h, Install wd80x3
* fb/fb.c, fb/skyeye_fb.h: Framebuffer support for skyeye simulator
* rtl8019/wd80x3, rtl8019/rtl8019.c: rtl8019 support
* startup/memmap.c: Change the size of Map I/O to 1216M
* bsp/bsp.h: Add rtl8019 related infomation
* configure.ac: Rename BSP_BOOTCARD_OPTIONS to
RTEMS_BSP_BOOTCARD_OPTIONS. Add RTEMS_BSP_CLEANUP_OPTIONS so all BSPs
have the same options.
* Makefile.am: Fix typo.
* Makefile.am: Complete update to current style.
* Makefile.am: Update to current style.
* bsp_specs: Fix warning for _start.
* start/start.S: Proper attribution for origin.
* startup/bspstart.c: Add Skyeye bsp_reset() on Skyeye.
* include/.cvsignore: New file.
* include/bspopts.h.in: Removed.
* startup/linkcmds: Fix spacing.
* configure.ac, include/bspopts.h.in: Add ON_SKYEYE option to at least
enable fast idle mode. Also added some standard BSP options.
* .cvsignore, ChangeLog, Makefile.am, README, bsp_specs, configure.ac,
preinstall.am, console/uarts.c, include/bsp.h, include/bspopts.h.in,
include/tm27.h, start/start.S, startup/bspstart.c, startup/linkcmds,
startup/memmap.c: New files.
