Update #3254.
maintain.
Update #3254.
BSP_PRESS_KEY_FOR_RESET=0
BSP_RESET_BOARD_AT_EXIT=1
BSP_PRINT_EXCEPTION_CONTEXT=1
Update #3239.
Update #2408.
The size of the sample executables without this option were:
58932 1700 67031844 67092476 3ffbffc minimum.exe
91364 1956 66999140 67092460 3ffbfec base_sp.exe
111756 2044 66978660 67092460 3ffbfec nsecs.exe
189636 2440 66900388 67092464 3ffbff0 capture.exe
203520 1984 66886976 67092480 3ffc000 cdtest.exe
178068 2340 66912068 67092476 3ffbffc paranoia.exe
104468 1908 66986084 67092460 3ffbfec hello.exe
553352 5892 66533220 67092464 3ffbff0 fileio.exe
94780 1956 66995716 67092452 3ffbfe4 ticker.exe
269384 6752 66816320 67092456 3ffbfe8 loopback.exe
590408 2176 66499872 67092456 3ffbfe8 cxx_iostream.exe
447928 12860 66631684 67092472 3ffbff8 pppd.exe
93476 1964 66997028 67092468 3ffbff4 unlimited.exe
The size of the sample executables with this option enabled were:
31352 1276 67059840 67092468 3ffbff4 minimum.exe
85492 1804 67005156 67092452 3ffbfe4 base_sp.exe
105964 1892 66984612 67092468 3ffbff4 nsecs.exe
181748 2280 66908420 67092448 3ffbfe0 capture.exe
195592 1832 66895040 67092464 3ffbff0 cdtest.exe
172044 2180 66918244 67092468 3ffbff4 paranoia.exe
96396 1748 66994308 67092452 3ffbfe4 hello.exe
537240 5740 66549476 67092456 3ffbfe8 fileio.exe
88884 1804 67001764 67092452 3ffbfe4 ticker.exe
249568 6504 66836384 67092456 3ffbfe8 loopback.exe
412652 2016 66677796 67092464 3ffbff0 cxx_iostream.exe
415208 12584 66664672 67092464 3ffbff0 pppd.exe
85728 1804 67004932 67092464 3ffbff0 unlimited.exe
Update #2408.
do
echo $b
# echo $g
-i $b
done
Fix typo.
closes 2345.
This section can be use to provide a cache coherent memory area via
rtems_cache_coherent_add_area().
building libchip/rtc
These flags are obsolete with the EABI based ARM tool chain.
not updated.
This is necessary to add tests that use the cache manager. For example
to get better estimates of worst-case timings.
Add reserved system events RTEMS_EVENT_SYSTEM_NETWORK_SBWAIT and
RTEMS_EVENT_SYSTEM_NETWORK_SOSLEEP.
Add and use rtems_bsdnet_event_send().
Conflicts:
Replace the "NIRVANA" region with the more verbose "UNEXPECTED_SECTIONS"
region. Move the region definition into the "linkcmds.base" files.
Many files had an extra blank line in the license text
found in the file header. This patch removes that line.
* The license and distribution terms for this file may be
* found in the file LICENSE in this distribution or at
* http://www.rtems.com/license/LICENSE.
The script that did this also turned off execute permission
when it was turned on incorrectly.
