These flags are obsolete with the EABI based ARM tool chain.
not updated.
This is necessary to add tests that use the cache manager. For example
to get better estimates of worst-case timings.
Add reserved system events RTEMS_EVENT_SYSTEM_NETWORK_SBWAIT and
RTEMS_EVENT_SYSTEM_NETWORK_SOSLEEP.
Add and use rtems_bsdnet_event_send().
Conflicts:
Replace the "NIRVANA" region with the more verbose "UNEXPECTED_SECTIONS"
region. Move the region definition into the "linkcmds.base" files.
Many files had an extra blank line in the license text
found in the file header. This patch removes that line.
* The license and distribution terms for this file may be
* found in the file LICENSE in this distribution or at
* http://www.rtems.com/license/LICENSE.
The script that did this also turned off execute permission
when it was turned on incorrectly.
PR 1953/bsps
* console/uarts.c: Do not use /dev/console in libchip configuration
table. Shared driver framework selects device to use as /dev/console.
PR 1917/bsps
* Makefile.am, console/uarts.c: Modifications to add dynamic tables for
libchip serial drivers.
* bsp_specs, start/start.S, startup/linkcmds: Use linker command base
file.
* rtl8019/rtl8019.c: Fix typo.
* rtl8019/rtl8019.c: Fixed interrupt handler.
* Makefile.am, preinstall.am: Added generic interrupt support modules.
* include/bsp.h: Define BSP_FEATURE_IRQ_EXTENSION.
* startup/bspstart.c, rtl8019/rtl8019.c: Interrupt support changes.
* csb336/make/custom/csb336.cfg,
csb337/make/custom/csb337.cfg, edb7312/make/custom/edb7312.cfg,
gba/make/custom/gba.cfg, gdbarmsim/make/custom/arm920.cfg,
gp32/make/custom/gp32.cfg, gumstix/make/custom/gumstix.cfg,
lpc32xx/make/custom/lpc32xx_phycore.cfg, nds/make/custom/nds.cfg,
rtl22xx/make/custom/rtl22xx.cfg, smdk2410/make/custom/smdk2410.cfg:
Use VFP floating point model.
* start/start.S: Verify boot_card() is passed a NULL.
* make/custom/gumstix.cfg: Remove RTEMS_BSP_FAMILY.
* make/custom/gumstix.cfg: New (relocated from /make/custom).
* configure.ac: Resolve confusion with Ralf's patch.
* configure.ac, fb/fb.c, include/bsp.h: updates made for porting to
Nano-X and make testing easyer
* configure.ac: Remove RTEMS_BSP_BOOTCARD_OPTIONS.
