* | bsps/arm: Add .nocache section | Sebastian Huber | 2014-11-27 | 1 | -0/+2 |
| | | | | | This section can be use to provide a cache coherent memory area via rtems_cache_coherent_add_area(). | ||||
* | bsps: Replace NIRVANA region | Sebastian Huber | 2012-06-12 | 1 | -1/+0 |
| | | | | | Replace the "NIRVANA" region with the more verbose "UNEXPECTED_SECTIONS" region. Move the region definition into the "linkcmds.base" files. | ||||
* | nds/linkcmds - Remove execute permission | Joel Sherrill | 2012-05-03 | 1 | -0/+0 |
* | 2010-12-03 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2010-12-03 | 1 | -215/+24 |
| | | | | | * bsp_specs, start/start.S, startup/linkcmds: Use linker command base file. | ||||
* | 2009-06-11 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-06-11 | 1 | -2/+0 |
| | | | | * startup/linkcmds: Fix spacing. | ||||
* | 2009-06-04 Xi Yang <hiyangxi@gmail.com> | Joel Sherrill | 2009-06-04 | 1 | -0/+219 |
* .cvsignore, ChangeLog, Makefile.am, README, bsp_specs, configure.ac, preinstall.am, console/uarts.c, include/bsp.h, include/bspopts.h.in, include/tm27.h, start/start.S, startup/bspstart.c, startup/linkcmds, startup/memmap.c: New files. |
