Update #3285.
* Makefile.am: Add fb/fb.c add rtl8019 Ethernet card support
* preinstall.am: Install skyeye_fb.h, Install wd80x3
* fb/fb.c, fb/skyeye_fb.h: Framebuffer support for skyeye simulator
* rtl8019/wd80x3, rtl8019/rtl8019.c: rtl8019 support
* startup/memmap.c: Change the size of Map I/O to 1216M
* bsp/bsp.h: Add rtl8019 related infomation
* include/wd80x3.h: Added file header and logic to prevent multiple
inclusions of this file.
* wd8003/wd8003.c: Corrected attach to include "int attach" parameter.
Here is a patch for KA9Q stack.
This patch contains an Ethernet Driver for Western Digital,
some fixes for the UDP and TCP protocols (for endian conversion)
and some little programs which allow the test of UDP and TCP
sockets via Ethernet.
I have tested that on an Intel machine. If someone can test it
on a big-endian machine, ...
