not updated.
Many files had an extra blank line in the license text
found in the file header. This patch removes that line.
* The license and distribution terms for this file may be
* found in the file LICENSE in this distribution or at
* http://www.rtems.com/license/LICENSE.
The script that did this also turned off execute permission
when it was turned on incorrectly.
* Makefile.am, preinstall.am: Added generic interrupt support modules.
* include/bsp.h: Define BSP_FEATURE_IRQ_EXTENSION.
* startup/bspstart.c, rtl8019/rtl8019.c: Interrupt support changes.
* Makefile.am: Add fb/fb.c add rtl8019 Ethernet card support
* preinstall.am: Install skyeye_fb.h, Install wd80x3
* fb/fb.c, fb/skyeye_fb.h: Framebuffer support for skyeye simulator
* rtl8019/wd80x3, rtl8019/rtl8019.c: rtl8019 support
* startup/memmap.c: Change the size of Map I/O to 1216M
* bsp/bsp.h: Add rtl8019 related infomation
* .cvsignore, ChangeLog, Makefile.am, README, bsp_specs, configure.ac,
preinstall.am, console/uarts.c, include/bsp.h, include/bspopts.h.in,
include/tm27.h, start/start.S, startup/bspstart.c, startup/linkcmds,
startup/memmap.c: New files.
