updates #2451.
XXX
* start/start.S, startup/linkcmds: Use linker command base file.
* start/start.S: Verify boot_card() is passed a NULL.
* start/start.S: Update for boot_card command line change.
* console/uart.c, start/start.S, startup/linkcmds, startup/memmap.c:
Correct license URL and/or fix mistake in copyright notice. Both of
these mistakes appear to be from code submitted after these changes
were made previously.
* acinclude.m4: Added gp32 BSP.
* gp32/.cvsignore, gp32/Makefile.am, gp32/README, gp32/bsp_specs,
gp32/configure.ac, gp32/console/.cvsignore, gp32/console/conio.c,
gp32/console/console.c, gp32/console/defaultfont.c,
gp32/include/.cvsignore, gp32/include/bsp.h, gp32/include/conio.h,
gp32/include/tm27.h, gp32/start/.cvsignore, gp32/start/start.S,
gp32/startup/.cvsignore, gp32/startup/bspstart.c,
gp32/startup/exit.c, gp32/startup/linkcmds, gp32/startup/memmap.c: New files.
* ChangeLog, Makefile.am, README, bsp_specs, configure.ac, times,
console/uart.c, include/bsp.h, include/tm27.h, network/lan91c11x.c,
network/lan91c11x.h, network/network.c, start/start.S,
startup/bspstart.c, startup/exit.c, startup/linkcmds,
