* gba/clock/clockdrv.c, gba/console/conio.c, gba/console/console.c,
gba/console/defaultfont.h, gba/include/arm_mode_bits.h,
gba/include/asm_macros.h, gba/include/bsp.h, gba/include/conio.h,
gba/include/gba.h, gba/include/gba_registers.h, gba/irq/irq.c,
gba/irq/irq.h, gba/startup/bspstart.c, gba/timer/timer.c,
gp32/include/bsp.h, gp32/startup/bspreset.c, gp32/startup/bspstart.c,
nds/tools/runtest, shared/comm/uart.c, shared/comm/uart.h,
smdk2410/include/bsp.h: Fix typo where license said
found in found in.
* Makefile.am, preinstall.am: Added generic interrupt support modules.
* include/bsp.h: Define BSP_FEATURE_IRQ_EXTENSION.
* startup/bspstart.c: Interrupt support changes.
* include/bsp.h: Eliminate BSPs defining NUMBER_OF_TERMIOS_PORTS.
Should be automatically handled by confdefs.h or the application.
* Makefile.am, preinstall.am: Use shared tm27.h stub.
* include/tm27.h: Removed.
* console/uart.c, include/bsp.h, smc/smc.c, startup/bspstart.c: Merge
smdk2410 with gp32.
* include/bsp.h, startup/bspstart.c: Fix idle task prototype.
* include/bsp.h, startup/bspstart.c: Eliminate copies of the
Configuration Table. Use the RTEMS provided accessor macros to obtain
configuration fields.
* include/bsp.h, startup/bspstart.c: Move interrupt_stack_size field
from CPU Table to Configuration Table. Eliminate CPU Table from all
ports. Delete references to CPU Table in all forms.
* Makefile.am, include/bsp.h, startup/bspstart.c: Moved most of the
remaining CPU Table fields to the Configuration Table. This included
pretasking_hook, predriver_hook, postdriver_hook, idle_task,
do_zero_of_workspace, extra_mpci_receive_server_stack,
stack_allocate_hook, and stack_free_hook. As a side-effect of this
effort some multiprocessing code was made conditional and some style
clean up occurred.
* Makefile.am: Remove lcd.rel, added console/uart.c,
removed conio stuffs.
* console/conio.c, console/console.c, console/defaultfont.c,
include/conio.h : files removed.
* console/uart.c: New file.
* include/bsp.h: lcd.c prototypes removed.
* startup/bspstart.c: bsp_reset() cause gp32 to reset to bios,
added a bsp_idle_task which put s3c2400 in a "wait for IRQ" state.
* bsp_specs: Add rules for cpp support
* include/bsp.h: Add gp32 support fct prototypes
* console/conio.c: Moved video buffer to 0x0c7ed000
* startup/bspstart.c: Add some init code, some cleaning...
* include/bsp.h: New header guard.
* acinclude.m4: Added gp32 BSP.
* gp32/.cvsignore, gp32/Makefile.am, gp32/README, gp32/bsp_specs,
gp32/configure.ac, gp32/console/.cvsignore, gp32/console/conio.c,
gp32/console/console.c, gp32/console/defaultfont.c,
gp32/include/.cvsignore, gp32/include/bsp.h, gp32/include/conio.h,
gp32/include/tm27.h, gp32/start/.cvsignore, gp32/start/start.S,
gp32/startup/.cvsignore, gp32/startup/bspstart.c,
gp32/startup/exit.c, gp32/startup/linkcmds, gp32/startup/memmap.c: New files.
