Change bsp_interrupt_vector_enable() and bsp_interrupt_vector_disable()
to not return a status code. Add bsp_interrupt_assert() and use it to
validate the vector number in the vector enable/disable implementations.
Update #2408.
This avoids potential dead code in _Thread_Handler(). It gets rid of
the dangerous function pointer casts.
Update #2514.
ARM1136JF-S
The size of the sample executables without this option were:
45920 1392 4146980 4194292 3ffff4 minimum.exe
88704 1668 4103908 4194280 3fffe8 base_sp.exe
109060 1756 4083460 4194276 3fffe4 nsecs.exe
186464 2144 4005668 4194276 3fffe4 capture.exe
200824 1696 3991776 4194296 3ffff8 cdtest.exe
174568 2044 4017668 4194280 3fffe8 paranoia.exe
102836 1636 4089828 4194300 3ffffc hello.exe
549204 5580 3639488 4194272 3fffe0 fileio.exe
92060 1668 4100576 4194304 400000 ticker.exe
265276 6440 3922560 4194276 3fffe4 loopback.exe
588468 1904 3603904 4194276 3fffe4 cxx_iostream.exe
441248 12556 3740480 4194284 3fffec pppd.exe
91712 1692 4100900 4194304 400000 unlimited.exe
The size of the sample executables with this option enabled were:
28228 1212 4164864 4194304 400000 minimum.exe
79944 1636 4112708 4194288 3ffff0 base_sp.exe
100388 1724 4092164 4194276 3fffe4 nsecs.exe
175784 2104 4016388 4194276 3fffe4 capture.exe
190152 1672 4002464 4194288 3ffff0 cdtest.exe
165632 2012 4026628 4194272 3fffe0 paranoia.exe
93276 1604 4099396 4194276 3fffe4 hello.exe
530500 5548 3658240 4194288 3ffff0 fileio.exe
83292 1636 4109376 4194304 400000 ticker.exe
242724 6328 3945248 4194300 3ffffc loopback.exe
409528 1880 3782884 4194292 3ffff4 cxx_iostream.exe
405816 12392 3776068 4194276 3fffe4 pppd.exe
82476 1668 4110144 4194288 3ffff0 unlimited.exe
ARM1136J-S
ARM7TDMI
47344 1392 4145540 4194276 3fffe4 minimum.exe
91352 1668 4101284 4194304 400000 base_sp.exe
111728 1756 4080804 4194288 3ffff0 nsecs.exe
190272 2144 4001860 4194276 3fffe4 capture.exe
203632 1696 3988960 4194288 3ffff0 cdtest.exe
179708 2044 4012548 4194300 3ffffc paranoia.exe
105184 1636 4087460 4194280 3fffe8 hello.exe
562224 5580 3626500 4194304 400000 fileio.exe
94788 1668 4097824 4194280 3fffe8 ticker.exe
270812 6440 3917024 4194276 3fffe4 loopback.exe
591284 1904 3601088 4194276 3fffe4 cxx_iostream.exe
449596 12556 3732128 4194280 3fffe8 pppd.exe
94400 1692 4098212 4194304 400000 unlimited.exe
29188 1212 4163904 4194304 400000 minimum.exe
82432 1636 4110212 4194280 3fffe8 base_sp.exe
102904 1724 4089668 4194296 3ffff8 nsecs.exe
179208 2104 4012964 4194276 3fffe4 capture.exe
192656 1672 3999968 4194296 3ffff8 cdtest.exe
170132 2012 4022148 4194292 3ffff4 paranoia.exe
95432 1604 4097252 4194288 3ffff0 hello.exe
542896 5548 3645860 4194304 400000 fileio.exe
85852 1636 4106816 4194304 400000 ticker.exe
247700 6328 3940256 4194284 3fffec loopback.exe
412032 1880 3780388 4194300 3ffffc cxx_iostream.exe
413348 12392 3768548 4194288 3ffff0 pppd.exe
84996 1668 4107616 4194280 3fffe8 unlimited.exe
ARM920
47416 1392 4145476 4194284 3fffec minimum.exe
91420 1668 4101216 4194304 400000 base_sp.exe
111812 1756 4080736 4194304 400000 nsecs.exe
190340 2144 4001796 4194280 3fffe8 capture.exe
203704 1696 3988896 4194296 3ffff8 cdtest.exe
179692 2044 4012548 4194284 3fffec paranoia.exe
105256 1636 4087396 4194288 3ffff0 hello.exe
562560 5580 3626148 4194288 3ffff0 fileio.exe
94848 1668 4097764 4194280 3fffe8 ticker.exe
270804 6440 3917056 4194300 3ffffc loopback.exe
591348 1904 3601024 4194276 3fffe4 cxx_iostream.exe
449616 12556 3732128 4194300 3ffffc pppd.exe
94476 1692 4098112 4194280 3fffe8 unlimited.exe
29268 1212 4163808 4194288 3ffff0 minimum.exe
82508 1636 4110144 4194288 3ffff0 base_sp.exe
102988 1724 4089568 4194280 3fffe8 nsecs.exe
179276 2104 4012900 4194280 3fffe8 capture.exe
192736 1672 3999872 4194280 3fffe8 cdtest.exe
170124 2012 4022148 4194284 3fffec paranoia.exe
95504 1604 4097188 4194296 3ffff8 hello.exe
543248 5548 3645508 4194304 400000 fileio.exe
85920 1636 4106724 4194280 3fffe8 ticker.exe
247676 6328 3940288 4194292 3ffff4 loopback.exe
412104 1880 3780292 4194276 3fffe4 cxx_iostream.exe
413392 12392 3768516 4194300 3ffffc pppd.exe
85080 1668 4107556 4194304 400000 unlimited.exe
ARM CORTEX A9
46628 1392 4146272 4194292 3ffff4 minimum.exe
89596 1668 4103040 4194304 400000 base_sp.exe
109968 1756 4082560 4194284 3fffec nsecs.exe
187540 2144 4004612 4194296 3ffff8 capture.exe
201824 1696 3990752 4194272 3fffe0 cdtest.exe
176032 2044 4016196 4194272 3fffe0 paranoia.exe
103636 1636 4089028 4194300 3ffffc hello.exe
550428 5580 3638272 4194280 3fffe8 fileio.exe
93148 1668 4099488 4194304 400000 ticker.exe
267048 6440 3920800 4194288 3ffff0 loopback.exe
589380 1904 3603008 4194292 3ffff4 cxx_iostream.exe
444292 12556 3737440 4194288 3ffff0 pppd.exe
92568 1692 4100036 4194296 3ffff8 unlimited.exe
28604 1212 4164480 4194296 3ffff8 minimum.exe
80652 1636 4112000 4194288 3ffff0 base_sp.exe
101116 1724 4091460 4194300 3ffffc nsecs.exe
176744 2104 4015428 4194276 3fffe4 capture.exe
190956 1672 4001664 4194292 3ffff4 cdtest.exe
166892 2012 4025380 4194284 3fffec paranoia.exe
93848 1604 4098820 4194272 3fffe0 hello.exe
531552 5548 3657184 4194284 3fffec fileio.exe
84200 1636 4108452 4194288 3ffff0 ticker.exe
244324 6328 3943648 4194300 3ffffc loopback.exe
410260 1880 3782148 4194288 3ffff0 cxx_iostream.exe
408736 12392 3773156 4194284 3fffec pppd.exe
83140 1668 4109472 4194280 3fffe8 unlimited.exe
Update #2408.
do
echo $b
# echo $g
-i $b
done
Fix typo.
closes 2345.
This section can be use to provide a cache coherent memory area via
rtems_cache_coherent_add_area().
The file console-polled.h provides the prototypes for the three
required methods when implementing a single port polled console
driver. This paradigm is common on simulators and simple hardware.
+ Updated the BSPs Makefile.am to make console-polled.h available.
+ Regenerated the BSPs preinstall.sm.
+ Updated console support files to include <bsp/console-polled.h>.
+ Updated console support files to make printk() support method static.
These flags are obsolete with the EABI based ARM tool chain.
not updated.
The following BSPs do not have tick support so the tests fail:
arm1136jfs
arm1136js
arm7tdmi
arm920
armcortexa9 (does not run any more)
avrtest
h8sim
h8sxsim
m32csim
m32rsim
moxiesim
simsh1
simsh2
simsh4
v850e1sim
v850e2sim
v850e2v3sim
v850esim
v850essim
v850sim
This list was provided by Joel in the following post:
http://www.rtems.org/pipermail/rtems-devel/2014-April/006526.html
Switch to the standard ARM startup code. This requires adding the
standard interrupt code. The interrupt code does nothing at this
point in time. I do not know if the ARM simulator in GDB supports
interrupts.
The syscall functions overlapped with RTEMS, for example _write, _read, etc.
Change these to be internal to the BSP and avoid any clash with names in
RTEMS. Add support for SWI_Write0.
Change the console driver to use SWI_Write0. This outputs the character
to the host's stdout. Writing to file name 0 is not captured and managed
by GDB's simulation code while the SWI_Write0 is. The managed stdout
data is encapulated in the MI protocol while writes to file handle 0 are
dropped by GDB when in MI mode.
This is necessary to add tests that use the cache manager. For example
to get better estimates of worst-case timings.
Conflicts:
Replace the "NIRVANA" region with the more verbose "UNEXPECTED_SECTIONS"
region. Move the region definition into the "linkcmds.base" files.
* include/swi.h, startup/bspreset.c, startup/syscalls.c:
* bsp_specs, start/start.S, startup/linkcmds: Use linker command base
file.
* startup/syscalls.c:
* startup/syscalls.c: Rename to avoid conflict with newlib.
