* | arm/gdbarmsim/irq/irq.c: Fix warnings | Joel Sherrill | 2014-10-09 | 1 | -0/+7 |
* | bsp/gdbarmsim: Switch to the standard arm/shared/startup. | Chris Johns | 2014-05-26 | 2 | -0/+114 |
Switch to the standard ARM startup code. This requires adding the standard interrupt code. The interrupt code does nothing at this point in time. I do not know if the ARM simulator in GDB supports interrupts. |
