* | Add console-polled.h and update all BSPs that should use it. | Joel Sherrill | 2014-10-10 | 1 | -1/+2 |
| | | | | | | | | | | | The file console-polled.h provides the prototypes for the three required methods when implementing a single port polled console driver. This paradigm is common on simulators and simple hardware. + Updated the BSPs Makefile.am to make console-polled.h available. + Regenerated the BSPs preinstall.sm. + Updated console support files to include <bsp/console-polled.h>. + Updated console support files to make printk() support method static. | ||||
* | bsp/gdbarmsim: Change syscall functions to not clash with RTEMS functions. | Chris Johns | 2014-05-26 | 1 | -3/+1 |
| | | | | | | | | | | | | The syscall functions overlapped with RTEMS, for example _write, _read, etc. Change these to be internal to the BSP and avoid any clash with names in RTEMS. Add support for SWI_Write0. Change the console driver to use SWI_Write0. This outputs the character to the host's stdout. Writing to file name 0 is not captured and managed by GDB's simulation code while the SWI_Write0 is. The managed stdout data is encapulated in the MI protocol while writes to file handle 0 are dropped by GDB when in MI mode. | ||||
* | Remove all .cvsignore files. | Joel Sherrill | 2012-02-01 | 1 | -8/+0 |
* | 2009-10-01 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-10-01 | 2 | -0/+69 |
* .cvsignore, ChangeLog, Makefile.am, bsp_specs, configure.ac, preinstall.am, console/.cvsignore, console/console-io.c, include/.cvsignore, include/bsp.h, include/irq.h, include/swi.h, start/.cvsignore, start/start.S, startup/.cvsignore, startup/bspreset.c, startup/bspstart.c, startup/linkcmds, startup/syscalls.c: New files. |
