* include/swi.h, startup/bspreset.c, startup/syscalls.c:
* bsp_specs, start/start.S, startup/linkcmds: Use linker command base
file.
* startup/syscalls.c:
* startup/syscalls.c: Rename to avoid conflict with newlib.
* csb336/make/custom/csb336.cfg,
csb337/make/custom/csb337.cfg, edb7312/make/custom/edb7312.cfg,
gba/make/custom/gba.cfg, gdbarmsim/make/custom/arm920.cfg,
gp32/make/custom/gp32.cfg, gumstix/make/custom/gumstix.cfg,
lpc32xx/make/custom/lpc32xx_phycore.cfg, nds/make/custom/nds.cfg,
rtl22xx/make/custom/rtl22xx.cfg, smdk2410/make/custom/smdk2410.cfg:
Use VFP floating point model.
* start/start.S: Verify boot_card() is passed a NULL.
* make/custom/arm1136jfs.cfg: Remove RTEMS_BSP_FAMILY.
* make/custom/arm1136js.cfg: Remove RTEMS_BSP_FAMILY.
* make/custom/arm7tdmi.cfg: Remove RTEMS_BSP_FAMILY.
* make/custom/arm920.cfg: Remove RTEMS_BSP_FAMILY.
* make/custom/armcortexa9.cfg: Remove RTEMS_BSP_FAMILY.
* make/custom/arm1136jfs.cfg: New (relocated from /make/custom).
* make/custom/arm1136js.cfg: New (relocated from /make/custom).
* make/custom/arm7tdmi.cfg: New (relocated from /make/custom).
* make/custom/arm920.cfg: New (relocated from /make/custom).
* make/custom/armcortexa9.cfg: New (relocated from /make/custom).
* .cvsignore, ChangeLog, Makefile.am, bsp_specs, configure.ac,
preinstall.am, console/.cvsignore, console/console-io.c,
include/.cvsignore, include/bsp.h, include/irq.h, include/swi.h,
start/.cvsignore, start/start.S, startup/.cvsignore,
startup/bspreset.c, startup/bspstart.c, startup/linkcmds,
startup/syscalls.c: New files.
