The TLS section symbols had wrong values in case of an empty TLS data
section and a nonempty TLS BSS section.
This is necessary to add tests that use the cache manager. For example
to get better estimates of worst-case timings.
Add doxygen to the header files in the arm/gba include,
irq, and console directories.
Rename arm_exc_interrupt() to _ARMV4_Exception_interrupt().
The work areas (RTEMS work space and C program heap) will be initialized
now in a separate step and are no longer part of
rtems_initialize_data_structures(). Initialization is performed with
tables of Heap_Area entries. This allows usage of scattered memory
areas present on various small scale micro-controllers.
The sbrk() support API changes also. The bsp_sbrk_init() must now deal
with a minimum size for the first memory chunk to take the configured
work space size into account.
Conflicts:
Many files had an extra blank line in the license text
found in the file header. This patch removes that line.
* The license and distribution terms for this file may be
* found in the file LICENSE in this distribution or at
* http://www.rtems.com/license/LICENSE.
The script that did this also turned off execute permission
when it was turned on incorrectly.
* Makefile.am: Fix broken path to clockdrv_shell.h.
* include/bsp.h, startup/bspreset.c:
* timer/timer.c: Include <rtems/btimer.h>.
* gba/clock/clockdrv.c, gba/console/conio.c, gba/console/console.c,
gba/console/defaultfont.h, gba/include/arm_mode_bits.h,
gba/include/asm_macros.h, gba/include/bsp.h, gba/include/conio.h,
gba/include/gba.h, gba/include/gba_registers.h, gba/irq/irq.c,
gba/irq/irq.h, gba/startup/bspstart.c, gba/timer/timer.c,
gp32/include/bsp.h, gp32/startup/bspreset.c, gp32/startup/bspstart.c,
nds/tools/runtest, shared/comm/uart.c, shared/comm/uart.h,
smdk2410/include/bsp.h: Fix typo where license said
found in found in.
* startup/linkcmds: Use linker command base file.
* irq/irq_asm.S, irq/irq_init.c, irq/bsp_irq_asm.S,
irq/bsp_irq_init.c: Removed files.
* Makefile.am, preinstall.am: Reflect changes above. Added generic
interrupt support modules.
* irq/irq.h, irq/irq.c: The previous interrupt warning fix changed the
interrupt handler API. To fix this problem the generic interrupt
support framework will be used now. This eliminates a lot of copy and
paste code. The interrupt header file is now <bsp/irq.h>.
* include/bsp.h: Define BSP_FEATURE_IRQ_EXTENSION.
* start/start.S, startup/bspstart.c, clock/clockdrv.c,
console/console.c, timer/timer.c: Interrupt support changes.
* csb336/make/custom/csb336.cfg,
csb337/make/custom/csb337.cfg, edb7312/make/custom/edb7312.cfg,
gba/make/custom/gba.cfg, gdbarmsim/make/custom/arm920.cfg,
gp32/make/custom/gp32.cfg, gumstix/make/custom/gumstix.cfg,
lpc32xx/make/custom/lpc32xx_phycore.cfg, nds/make/custom/nds.cfg,
rtl22xx/make/custom/rtl22xx.cfg, smdk2410/make/custom/smdk2410.cfg:
Use VFP floating point model.
* start/start.S: Verify boot_card() is passed a NULL.
* console/conio.c, console/console.c, include/conio.h:
Let *getch return "int". Remove casts.
* make/custom/gba.cfg: Remove RTEMS_BSP_FAMILY.
* make/custom/gba.cfg: New (relocated from /make/custom).
* configure.ac: Remove RTEMS_BSP_BOOTCARD_OPTIONS.
* include/bsp.h: Eliminate BSPs defining NUMBER_OF_TERMIOS_PORTS.
Should be automatically handled by confdefs.h or the application.
* configure.ac: Rename BSP_BOOTCARD_OPTIONS to
RTEMS_BSP_BOOTCARD_OPTIONS. Add RTEMS_BSP_CLEANUP_OPTIONS so all BSPs
have the same options.
* startup/bspgetworkarea.c: Switch from ssize_t to uintptr_t for
bsp_get_work_area() since the work area is larger than a single
allocatable object.
* start/start.S: Update for boot_card command line change.
PR 1385/cpukit
* irq/irq_asm.S: When the type rtems_boolean was switched to the C99
bool, the size changed from 4 bytes to 1 byte. The interrupt
dispatching code accesses two boolean variables for scheduling
purposes and the assembly implementations of this code did not get
updated.
