* Makefile.am: Fix broken path to clockdrv_shell.h.
* include/bsp.h, startup/bspreset.c:
* timer/timer.c: Include <rtems/btimer.h>.
* startup/linkcmds: Use linker command base file.
* irq/irq_asm.S, irq/irq_init.c, irq/bsp_irq_asm.S,
irq/bsp_irq_init.c: Removed files.
* Makefile.am, preinstall.am: Reflect changes above. Added generic
interrupt support modules.
* irq/irq.h, irq/irq.c: The previous interrupt warning fix changed the
interrupt handler API. To fix this problem the generic interrupt
support framework will be used now. This eliminates a lot of copy and
paste code. The interrupt header file is now <bsp/irq.h>.
* include/bsp.h: Define BSP_FEATURE_IRQ_EXTENSION.
* start/start.S, startup/bspstart.c, clock/clockdrv.c,
console/console.c, timer/timer.c: Interrupt support changes.
* csb336/make/custom/csb336.cfg,
csb337/make/custom/csb337.cfg, edb7312/make/custom/edb7312.cfg,
gba/make/custom/gba.cfg, gdbarmsim/make/custom/arm920.cfg,
gp32/make/custom/gp32.cfg, gumstix/make/custom/gumstix.cfg,
lpc32xx/make/custom/lpc32xx_phycore.cfg, nds/make/custom/nds.cfg,
rtl22xx/make/custom/rtl22xx.cfg, smdk2410/make/custom/smdk2410.cfg:
Use VFP floating point model.
* start/start.S: Verify boot_card() is passed a NULL.
* console/conio.c, console/console.c, include/conio.h:
Let *getch return "int". Remove casts.
* make/custom/gba.cfg: Remove RTEMS_BSP_FAMILY.
* make/custom/gba.cfg: New (relocated from /make/custom).
* configure.ac: Remove RTEMS_BSP_BOOTCARD_OPTIONS.
* include/bsp.h: Eliminate BSPs defining NUMBER_OF_TERMIOS_PORTS.
Should be automatically handled by confdefs.h or the application.
* configure.ac: Rename BSP_BOOTCARD_OPTIONS to
RTEMS_BSP_BOOTCARD_OPTIONS. Add RTEMS_BSP_CLEANUP_OPTIONS so all BSPs
have the same options.
* startup/bspgetworkarea.c: Switch from ssize_t to uintptr_t for
bsp_get_work_area() since the work area is larger than a single
allocatable object.
* start/start.S: Update for boot_card command line change.
PR 1385/cpukit
* irq/irq_asm.S: When the type rtems_boolean was switched to the C99
bool, the size changed from 4 bytes to 1 byte. The interrupt
dispatching code accesses two boolean variables for scheduling
purposes and the assembly implementations of this code did not get
updated.
* startup/cpu.c: Now compiles. Does not run.
* startup/cpu.c: Add missing prototype.
* bsp_specs: Remove -Qy from *link.
* bsp_specs: Move -e start from *link to *startfile to avoid warning
for undefined entry symbol when linking relocatables with binutils
2.19.
* Makefile.am, preinstall.am: Use shared tm27.h stub.
* include/tm27.h: Removed.
* startup/bspgetworkarea.c: Change size_t to ssize_t on
bsp_get_work_area(). On 16-bit architectures, size_t can be 16-bits
which would limit the work area to 64K.
* clock/clockdrv.c: include "../../../shared/clockdrv_shell.h".
* console/defaultfont.c: Remove (Renamed into console/defaultfont.h).
* console/defaultfont.h: New (Renamed from console/defaultfont.c).
* Makefile.am, console/conio.c: Reflect renamer.
* Makefile.am: Eliminate bsp.am. Build startup files as side-effect
of building libbspstart.a, using automake-rules.
* Makefile.am: Eliminate *_SOURCES.
* Makefile.am: Move noinst_LIBRARIES = libbsp.a before its
components.
* Makefile.am: Cleanup ../../shared/include/bootcard.h handling.
* Makefile.am: Remove empty HAS_NETWORKING conditional.
* configure.ac: Make letting boot_card() handle work area allocation
mandatory. Rename RTEMS_BSP_BOOTCARD_HANDLES_RAM_ALLOCATION to
* startup/bspreset.c: New file.
* Makefile.am, configure.ac, console/console.c: Use standardized
bsp_cleanup() which can optionally print a message, poll for user to
press key, and call bsp_reset(). Using this eliminates the various
bsp_cleanup() implementations which had their own implementation and
variety of string constants.
* startup/bspclean.c: Removed.
* startup/bspstart.c: Remove unnecessary includes of
rtems/libcsupport.h and rtems/libio.h.
* Makefile.am, configure.ac, startup/bspstart.c: Now support
bsp_get_work_area() and used shared implementation of it and
bsp_pretasking_hook. Ticker runs.
* startup/bspgetworkarea.c: New file.
* startup/bspstart.c: Review of all bsp_cleanup() implementations. In
this phase, all prototypes were removed from bsp.h and empty
implementations were removed and made to use the shared stub.
* irq/irq.c: Minor "bool" fixes.
* gba/startup/cpu.c, gba/timer/timer.c: Convert to "bool".
* timer/timer.c: Eliminate empty function from every benchmark timer
driver. Fix spelling.
* timer/timer.c: Rename timer driver methods to follow RTEMS
programming conventions.
* timer/timer.c: Eliminate rtems_boolean.
* Makefile.am: No BSP should use exit.c as a file name. exit() is POSIX
routine.
* startup/bspclean.c: New file.
* startup/exit.c: Removed.
* clock/clockdrv.c: Add missing prototypes.
* Makefile.am: Rework to avoid .rel files.
* startup/bspstart.c: Refactored and renamed initialization routines to
rtems_initialize_data_structures, rtems_initialize_before_drivers,
rtems_initialize_device_drivers, and
rtems_initialize_start_multitasking. This opened the sequence up so
that bootcard() could provide a more robust and flexible framework
which is easier to explain and understand. This also lays the
groundwork for sharing the division of available memory between the
RTEMS workspace and heap and the C library initialization across all
BSPs.
