Replace the "NIRVANA" region with the more verbose "UNEXPECTED_SECTIONS"
region. Move the region definition into the "linkcmds.base" files.
Many files had an extra blank line in the license text
found in the file header. This patch removes that line.
* The license and distribution terms for this file may be
* found in the file LICENSE in this distribution or at
* http://www.rtems.com/license/LICENSE.
The script that did this also turned off execute permission
when it was turned on incorrectly.
PR 1917/bsps
* Makefile.am, console/uart.c: Modifications to add dynamic tables for
libchip serial drivers.
* Makefile.am: Fix broken path to clockdrv_shell.h.
* startup/bspreset.c:
* timer/timer.c: Include <rtems/btimer.h>.
* bsp_specs, start/start.S, startup/linkcmds: Use linker command base
file.
* irq/bsp_irq_init.c: Removed file.
* Makefile.am, preinstall.am: Reflect change above. Added generic
interrupt support modules.
* include/bsp.h: Define BSP_FEATURE_IRQ_EXTENSION.
* startup/bspstart.c, irq/bsp_irq_asm.S, clock/clockdrv.c,
network/network.c: Interrupt support changes.
* csb336/make/custom/csb336.cfg,
csb337/make/custom/csb337.cfg, edb7312/make/custom/edb7312.cfg,
gba/make/custom/gba.cfg, gdbarmsim/make/custom/arm920.cfg,
gp32/make/custom/gp32.cfg, gumstix/make/custom/gumstix.cfg,
lpc32xx/make/custom/lpc32xx_phycore.cfg, nds/make/custom/nds.cfg,
rtl22xx/make/custom/rtl22xx.cfg, smdk2410/make/custom/smdk2410.cfg:
Use VFP floating point model.
* console/uart.c: Reflect termios API changes.
* start/start.S: Verify boot_card() is passed a NULL.
* make/custom/edb7312.cfg: Remove RTEMS_BSP_FAMILY.
* make/custom/edb7312.cfg: New (relocated from /make/custom).
* configure.ac: Remove RTEMS_BSP_BOOTCARD_OPTIONS.
* include/ep7312.h, startup/bspreset.c: Move Skyeye magic address out
of .h file.
* include/bsp.h: Eliminate BSPs defining NUMBER_OF_TERMIOS_PORTS.
Should be automatically handled by confdefs.h or the application.
* clock/clockdrv.c: Tinker with clock on Skyeye.
* clock/clockdrv.c: Add stub nanoseconds since last tick handler to
improve coverage.
* configure.ac: undefine BSP_PRESS_KEY_FOR_RESET
* startup/bspreset.c, include/ep7312.h: Support skyeye shutdown device
* configure.ac: Rename BSP_BOOTCARD_OPTIONS to
RTEMS_BSP_BOOTCARD_OPTIONS. Add RTEMS_BSP_CLEANUP_OPTIONS so all BSPs
have the same options.
* configure.ac, clock/clockdrv.c, startup/bspreset.c: Adjust clock
initialization for clock tick so rtmonuse test now runs on Skyeye.
Joel added configure magic and place holder in bspreset.c for Skyeye
hardware reset device support.
* start/start.S: Update for boot_card command line change.
* bsp_specs: Remove -Qy from *link.
* bsp_specs: Move -e start from *link to *startfile to avoid warning
for undefined entry symbol when linking relocatables with binutils
2.19.
* Makefile.am, preinstall.am: Use shared tm27.h stub.
* include/tm27.h: Removed.
* clock/clockdrv.c: include "../../../shared/clockdrv_shell.h".
* Makefile.am: Eliminate bsp.am. Build startup files as side-effect
of building libbspstart.a, using automake-rules.
* Makefile.am: Eliminate *_SOURCES.
* Makefile.am: Move noinst_LIBRARIES = libbsp.a before its
components.
* Makefile.am: Cleanup ../../shared/include/bootcard.h handling.
* configure.ac: Make letting boot_card() handle work area allocation
mandatory. Rename RTEMS_BSP_BOOTCARD_HANDLES_RAM_ALLOCATION to
* startup/bspreset.c: New file.
* Makefile.am, configure.ac, console/uart.c: Use standardized
bsp_cleanup() which can optionally print a message, poll for user to
press key, and call bsp_reset(). Using this eliminates the various
bsp_cleanup() implementations which had their own implementation and
variety of string constants.
* startup/bspclean.c: Removed.
* Makefile.am, startup/linkcmds: Use top level shared
bsp_get_work_area() implementation.
* startup/bspstart.c: Remove unnecessary includes of
rtems/libcsupport.h and rtems/libio.h.
* Makefile.am: Split out bsp_get_work_area() into its own file and user
BSP Framework to perform more initialization. Let edb7312 and csb336
shared the implementation.
* startup/bspgetworkarea.c: Removed.
* Makefile.am, configure.ac, startup/bspstart.c: Split out
bsp_get_work_area() into its own file and user BSP Framework to
* startup/bspgetworkarea.c: New file.
* timer/timer.c: Use "true" instead of "1" for "bool"s.
