path: root/c/src/lib/libbsp/arm/edb7312 (follow)
* 2004-02-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-122-1/+5
| | | | * Makefile.am: Use CPPASCOMPILE instead of CCASCOMPILE.
* 2004-02-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-062-2/+8
| | | | | * Makefile.am: Pickup files from ../../arm/shared instead of ../shared. Reformat.
* 2004-01-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-284-5/+9
| | | | | | * include/bsp.h: Remove config. * irq/irq.c: Remove stray blanks. * start/start.S: Add missing */ in comments.
* include/.cvsignore: Remove unnecessary entriesRalf Corsepius2004-01-281-2/+0
* Remove unused .cvsignoreRalf Corsepius2004-01-288-112/+0
* 2004-01-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-2811-306/+153
| | | | | | | | | | | * Makefile.am: Merge-in clock/Makefile.am, console/Makefile.am, network/Makefile.am, irq/Makefile.am, start/Makefile.am, startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am. Use automake compilation rules. * clock/Makefile.am, console/Makefile.am, network/Makefile.am, irq/Makefile.am, start/Makefile.am, startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am: Remove. * configure.ac: Reflect changes above.
* 2004-01-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-213-1/+11
| | | | | * Makefile.am: Add PREINSTALL_DIRS. * irq/Makefile.am: Ditto.
* 2004-01-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-145-0/+23
| | | | | | | | * Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES. Add PRE/TMPINSTALL_FILES to CLEANFILES. * irq/Makefile.am: Ditto. * start/Makefile.am: Ditto. * startup/Makefile.am: Ditto.
* 2004-01-05 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-052-7/+7
| | | | | * wrapup/Makefile.am: Eliminate $(LIB). Use noinst_DATA to trigger building libbsp.a.
* Added PR541 in comment.Joel Sherrill2003-12-161-0/+1
* 2003-12-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-152-1/+4
| | | | * startup/linkcmds: Remove SEARCH_DIR.
* 2003-12-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-133-12/+17
| | | | | * start/Makefile.am: s,${PROJECT_RELEASE}/lib,$(PROJECT_LIB),g. * startup/Makefile.am: s,${PROJECT_RELEASE}/lib,$(PROJECT_LIB),g.
* 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-124-2/+15
| | | | | | * irq/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES. * start/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES. * startup/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-122-2/+6
| | | | * configure.ac: Require automake >= 1.8, autoconf >= 2.59.
* 2003-12-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-095-30/+26
| | | | | | | * network/Makefile.am: Misc cleanups and fixes. * start/Makefile.am: Misc cleanups and fixes. * startup/Makefile.am: Misc cleanups and fixes. * wrapup/Makefile.am: Misc cleanups and fixes.
* 2003-12-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-035-26/+26
| | | | | | | * Makefile.am: Add preinstallation dirstamp support. * irq/Makefile.am: Add preinstallation dirstamp support. * network/Makefile.am: Cosmetics. * wrapup/Makefile.am: Cosmetics.
* 2003-12-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-029-8/+19
| | | | | | | | | | | * clock/Makefile.am: Remove all-local: $(ARCH). * console/Makefile.am: Remove all-local: $(ARCH). * irq/Makefile.am: Remove all-local: $(ARCH). * network/Makefile.am: Remove all-local: $(ARCH). * start/Makefile.am: Remove all-local: $(ARCH). * startup/Makefile.am: Remove all-local: $(ARCH). * timer/Makefile.am: Remove all-local: $(ARCH). * wrapup/Makefile.am: Remove all-local: $(ARCH).
* 2003-09-29 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-09-294-28/+22
| | | | | | | * Makefile.am: Merge-in include/Makefile.am. Reflect changes to bsp.am. * include/Makefile.am: Remove. * configure.ac: Reflect changes above.
* 2003-09-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-09-182-8/+4
| | | | * bsp_specs: Remove *lib:.
* 2003-09-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-0414-13/+20
| | | | | | | * clock/clockdrv.c, console/uart.c, include/bsp.h, include/ep7312.h, irq/bsp_irq_asm.S, irq/bsp_irq_init.c, irq/irq.c, irq/irq.h, start/start.S, startup/bspstart.c, startup/exit.c, startup/linkcmds, timer/timer.c: URL for license changed.
* 2003-08-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-182-1/+5
| | | | * Makefile.am: Reflect having moved aclocal/.
* Fix broken ChangeLog entries.Ralf Corsepius2003-08-181-10/+10
* 2003-08-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-1611-27/+40
| | | | | | | | | | | | | Makefile.am: Reflect having moved automake. clock/Makefile.am: Reflect having moved automake. console/Makefile.am: Reflect having moved automake. include/Makefile.am: Reflect having moved automake. irq/Makefile.am: Reflect having moved automake. network/Makefile.am: Reflect having moved automake. start/Makefile.am: Reflect having moved automake. startup/Makefile.am: Reflect having moved automake. timer/Makefile.am: Reflect having moved automake. wrapup/Makefile.am: Reflect having moved automake.
* Correcting to include PR numbers.Joel Sherrill2003-08-141-0/+2
* 2003-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-112-1/+5
| | | | * configure.ac: Use rtems-bugs@rtems.com as bug report email address.
* 2003-08-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-062-3/+5
| | | | | * bsp_specs: Remove -D__embedded__ -Asystem(embedded) from cpp. Remove cpp, old_cpp (now unused).
* 2003-08-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-062-1/+5
| | | | * bsp_specs: Remove -DUSE_ENHANCED_INTR_API.
* Merger from rtems-4-6-branch.Ralf Corsepius2003-03-112-1/+4
* 2003-02-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-02-112-1/+5
| | | | * configure.ac: AM_INIT_AUTOMAKE([1.7.2]).
| | | | * configure.ac: AC_PREREQ(2.57).
* 2003-01-20 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-01-202-0/+15
| | | | * startup/linkcmds: Add FreeBSD SYSCTL() sections for networking.
* 2002-12-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-12-138-7/+10
| | | | | | | | | | * clock/Makefile.am: Don't include @RTEMS_BSP@.cfg. * console/Makefile.am: Don't include @RTEMS_BSP@.cfg. * irq/Makefile.am: Don't include @RTEMS_BSP@.cfg. * network/Makefile.am: Don't include @RTEMS_BSP@.cfg. * start/Makefile.am: Don't include @RTEMS_BSP@.cfg. * startup/Makefile.am: Don't include @RTEMS_BSP@.cfg. * timer/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* 2002-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-12-122-1/+7
| | | | * start/Makefile.am: Use install-data-local to install startfile.
* 2002-12-10 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-12-102-1/+4
| | | | * wrapup/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* 2002-12-02 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-12-024-1/+12
| | | | | * configure.ac, network/Makefile.am: Don't build if networking disabled. * startup/linkcmds: Add sections to remove warnings.
* 2002-11-17 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-11-182-1/+5
| | | | * network/network.c: Fix inconsistency in prototyping.
* 2002-11-13 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-11-132-1/+5
| | | | * network/network.c: Removed warning per Jay's suggestion.
* 2002-11-13 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-11-133-12/+24
| | | | | * include/.cvsignore: Corrected. * network/.cvsignore: New file.
* 2002-11-13 Jay Monkman <jtm@smoothsmoothie.com>Joel Sherrill2002-11-1338-0/+2821
* New BSP. * .cvsignore, ChangeLog, Makefile.am, bsp_specs, configure.ac, README, times, clock/.cvsignore, clock/Makefile.am, clock/clockdrv.c, console/.cvsignore, console/Makefile.am, console/uart.c, include/.cvsignore, include/Makefile.am, include/bsp.h, include/ep7312.h, irq/.cvsignore, irq/Makefile.am, irq/bsp_irq_asm.S, irq/bsp_irq_init.c, irq/irq.c, irq/irq.h, network/Makefile.am, network/network.c, start/.cvsignore, start/Makefile.am, start/start.S, startup/.cvsignore, startup/Makefile.am, startup/bspstart.c, startup/exit.c, startup/linkcmds, timer/.cvsignore, timer/Makefile.am, timer/timer.c, wrapup/.cvsignore, wrapup/Makefile.am: New file.
