* irq/bsp_irq_init.c: Removed file.
* Makefile.am, preinstall.am: Reflect change above. Added generic
interrupt support modules.
* include/bsp.h: Define BSP_FEATURE_IRQ_EXTENSION.
* startup/bspstart.c, irq/bsp_irq_asm.S, clock/clockdrv.c,
network/network.c: Interrupt support changes.
* clock/clockdrv.c: Tinker with clock on Skyeye.
* clock/clockdrv.c: Add stub nanoseconds since last tick handler to
improve coverage.
* configure.ac, clock/clockdrv.c, startup/bspreset.c: Adjust clock
initialization for clock tick so rtmonuse test now runs on Skyeye.
Joel added configure magic and place holder in bspreset.c for Skyeye
hardware reset device support.
* clock/clockdrv.c: include "../../../shared/clockdrv_shell.h".
* clock/clockdrv.c, include/bsp.h, startup/bspstart.c: Eliminate copies
of the Configuration Table. Use the RTEMS provided accessor macros to
obtain configuration fields.
* clock/clockdrv.c: Fix spacing.
* clock/clockdrv.c: Remove warnings.
network/Makefile.am, irq/Makefile.am, start/Makefile.am,
startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am. Use automake
compilation rules.
* clock/Makefile.am, console/Makefile.am, network/Makefile.am,
irq/Makefile.am, start/Makefile.am, startup/Makefile.am,
timer/Makefile.am, wrapup/Makefile.am: Remove.
* irq/Makefile.am: Remove all-local: $(ARCH).
* clock/clockdrv.c, console/uart.c, include/bsp.h, include/ep7312.h,
irq/bsp_irq_asm.S, irq/bsp_irq_init.c, irq/irq.c, irq/irq.h,
start/start.S, startup/bspstart.c, startup/exit.c, startup/linkcmds,
timer/timer.c: URL for license changed.
irq/Makefile.am: Reflect having moved automake.
* irq/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* New BSP.
* .cvsignore, ChangeLog, Makefile.am, bsp_specs, configure.ac, README,
times, clock/.cvsignore, clock/Makefile.am, clock/clockdrv.c,
console/.cvsignore, console/Makefile.am, console/uart.c,
include/ep7312.h, irq/.cvsignore, irq/Makefile.am, irq/bsp_irq_asm.S,
irq/bsp_irq_init.c, irq/irq.c, irq/irq.h, network/Makefile.am,
network/network.c, start/.cvsignore, start/Makefile.am,
start/start.S, startup/.cvsignore, startup/Makefile.am,
timer/.cvsignore, timer/Makefile.am, timer/timer.c,
wrapup/.cvsignore, wrapup/Makefile.am: New file.
