* | 2010-12-03 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2010-12-03 | 1 | -1/+1 |
| | | | | | * bsp_specs, start/start.S, startup/linkcmds: Use linker command base file. | ||||
* | 2008-12-05 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-12-05 | 1 | -1/+1 |
| | | | | * bsp_specs: Remove -Qy from *link. | ||||
* | 2008-12-04 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-12-04 | 1 | -2/+2 |
| | | | | | | * bsp_specs: Move -e start from *link to *startfile to avoid warning for undefined entry symbol when linking relocatables with binutils 2.19. | ||||
* | 2007-04-12 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-04-12 | 1 | -4/+2 |
| | | | | * bsp_specs: Remove qrtems_debug. | ||||
* | 2006-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-11-01 | 1 | -1/+1 |
| | | | | * bsp_specs: Fix typo. | ||||
* | 2006-10-30 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-10-30 | 1 | -2/+5 |
| | | | | * bsp_specs: Add crti, crtbegin, crtend, and crtn. | ||||
* | 2003-09-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-09-18 | 1 | -8/+0 |
| | | | | * bsp_specs: Remove *lib:. | ||||
* | 2003-08-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-08-06 | 1 | -3/+0 |
| | | | | | * bsp_specs: Remove -D__embedded__ -Asystem(embedded) from cpp. Remove cpp, old_cpp (now unused). | ||||
* | 2003-08-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-08-06 | 1 | -1/+1 |
| | | | | * bsp_specs: Remove -DUSE_ENHANCED_INTR_API. | ||||
* | 2002-11-13 Jay Monkman <jtm@smoothsmoothie.com> | Joel Sherrill | 2002-11-13 | 1 | -0/+23 |
* New BSP. * .cvsignore, ChangeLog, Makefile.am, bsp_specs, configure.ac, README, times, clock/.cvsignore, clock/Makefile.am, clock/clockdrv.c, console/.cvsignore, console/Makefile.am, console/uart.c, include/.cvsignore, include/Makefile.am, include/bsp.h, include/ep7312.h, irq/.cvsignore, irq/Makefile.am, irq/bsp_irq_asm.S, irq/bsp_irq_init.c, irq/irq.c, irq/irq.h, network/Makefile.am, network/network.c, start/.cvsignore, start/Makefile.am, start/start.S, startup/.cvsignore, startup/Makefile.am, startup/bspstart.c, startup/exit.c, startup/linkcmds, timer/.cvsignore, timer/Makefile.am, timer/timer.c, wrapup/.cvsignore, wrapup/Makefile.am: New file. |
