2002-11-13 | 2002-11-13 Jay Monkman <jtm@smoothsmoothie.com> | Joel Sherrill | 1 | -0/+1 | |
* New BSP. * .cvsignore, ChangeLog, Makefile.am, bsp_specs, configure.ac, README, times, clock/.cvsignore, clock/Makefile.am, clock/clockdrv.c, console/.cvsignore, console/Makefile.am, console/uart.c, include/.cvsignore, include/Makefile.am, include/bsp.h, include/ep7312.h, irq/.cvsignore, irq/Makefile.am, irq/bsp_irq_asm.S, irq/bsp_irq_init.c, irq/irq.c, irq/irq.h, network/Makefile.am, network/network.c, start/.cvsignore, start/Makefile.am, start/start.S, startup/.cvsignore, startup/Makefile.am, startup/bspstart.c, startup/exit.c, startup/linkcmds, timer/.cvsignore, timer/Makefile.am, timer/timer.c, wrapup/.cvsignore, wrapup/Makefile.am: New file. | |||||
2000-07-26 | Port of RTEMS to the Texas Instruments C3x/C4x DSP families including | Joel Sherrill | 1 | -0/+0 | |
a BSP (c4xsim) supporting the simulator included with gdb. This port was done by Joel Sherrill and Jennifer Averett of OAR Corporation. Also included with this port is a space/time optimization to eliminate FP context switch management on CPUs without hardware or software FP. An issue with this port was that sizeof(unsigned32) = sizeof(unsigned8) on this CPU. This required addressing alignment checks and assumptions as well as fixing code that assumed sizeof(unsigned32) == 4. | |||||
2000-04-13 | Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>. | Joel Sherrill | 1 | -0/+13 | |
adds .cvsignore. |
