Update #3285.
Update #3285.
Update #2408.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
The umon support is only used by the csb337 BSP.
Update #3285.
Update #3285.
Update #3285.
* bsps/shared/cache
Update #3285.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
Update #3254.
EXTRA_DIST += foobar
in fragments.
Update #3254.
Update #3254.
Update #3254.
header file.
Update #3254.
maintain.
Update #3254.
Update #3239.
BSPs.
The original ARM architecture wide cache_.h is changed to dummy version
for targets not implementing/enablig cache at all.
The ARM targets equipped by cache should include
appropriate implementation.
Next options are available for now
c/src/lib/libbsp/arm/shared/armv467ar-basic-cache/cache_.h
basic ARM cache integrated on the CPU core directly
which requires only CP15 oparations
c/src/lib/libbsp/arm/shared/arm-l2c-310/cache_.h
support for case where ARM L2C-310 cache controller
is used. It is accessible as mmaped peripheral.
c/src/lib/libbsp/arm/shared/armv7m/include/cache_.h
Cortex-M specific cache support
Update #2408.
Update #2408.
This is necessary to add tests that use the cache manager. For example
to get better estimates of worst-case timings.
PR 1917/bsps
* Makefile.am, console/uarts.c: Modifications to add dynamic tables for
libchip serial drivers.
* Makefile.am, preinstall.am: Added generic interrupt support modules.
* include/bsp.h: Define BSP_FEATURE_IRQ_EXTENSION.
* startup/bspstart.c, network/network.c: Interrupt support changes.
* Makefile.am, preinstall.am, console/fbcons.c, console/font8x16.h,
console/sed1356.c, console/uarts.c, include/sed1356.h,
startup/bspstart.c, startup/linkcmds.csb337, startup/linkcmds.csb637,
startup/memmap.c, startup/umonsupp.c: Update to match development
version.
* Makefile.am, configure.ac, console/uarts.c: Add initial support for
Kit637 version of CSB637.
* README.kit637_v6, make/custom/kit637_v6.cfg: New files.
* configure.ac: Add RTEMS_BSP_LINKCMDS.
* make/custom/csb637.cfg: Remove LDFLAGS. Remove RTEMS_LINKCMDS.
* startup/linkcmds: Remove (Rename into linkcmds.csb337).
* startup/linkcmds.csb337: New (Renamed from linkcmds).
* Makefile.am: Rework linkcmds handling.
* Makefile.am, configure.ac, console/uarts.c: Add console device that
uses MicroMonitor to do actual input and output. This driver should
work on any board that uses MicroMonitor.
* Makefile.am, preinstall.am: Make an RTEMS specific umon.h wrapper
include file.
* Makefile.am: Re-add basic console code.
* Makefile.am: Add MicroMonitor support.
* Makefile.am, preinstall.am: Add MicroMonitor support.
* startup/umonsupp.c: New file.
* Makefile.am, configure.ac, preinstall.am, console/uarts.c,
include/bsp.h, startup/memmap.c: Add support for /dev/fbcons which is
a console type output only device to print to the LCD screen. The
video controller (SED) and fonts are copied from MicroMonitor and
proper attribution is made in those files and confirmed by Ed Sutter.
* console/fbcons.c, console/font8x16.h, console/sed1356.c,
console/sed1356_16bit.h, include/sed1356.h: New files.
* Makefile.am, README, configure.ac, preinstall.am, start/start.S,
startup/memmap.c: Add csb637 as alias and variant.
* startup/linkcmds.csb637: New file.
* Makefile.am, preinstall.am: Use shared tm27.h stub.
* include/tm27.h: Removed.
* Makefile.am: Eliminate bsp.am. Build startup files as side-effect
of building libbspstart.a, using automake-rules.
* Makefile.am: Eliminate *_SOURCES.
