* | 2006-06-02 Jay Monkman <jtm@lopingdog.com> | Jay Monkman | 2006-06-03 | 2 | -3/+5 |
| | | | | | * startup/linkcmds: Removed unnecessary global definition of bsp_vector_table. | ||||
* | 2006-06-02 Jay Monkman <jtm@lopingdog.com> | Jay Monkman | 2006-06-03 | 2 | -131/+139 |
| | | | | * times: Reran timing tests and updated 'times' file. | ||||
* | 2006-06-02 Jay Monkman <jtm@lopingdog.com> | Jay Monkman | 2006-06-03 | 2 | -12/+35 |
| | | | | * startup/bspstart.c: Fixed PLL calculations. | ||||
* | 2006-06-02 Jay Monkman <jtm@lopingdog.com> | Jay Monkman | 2006-06-03 | 3 | -197/+389 |
| | | | | | * Makefile.am, console/uart.c, startup/exit.c: Changed UART driver to be interrupt driven, added support for both UARTs. | ||||
* | 2006-06-02 Jay Monkman | Jay Monkman | 2006-06-03 | 2 | -12/+18 |
| | | | | | * network/network.c: Changed interrupt handling to use shared rtems_irq_connect_data struct. | ||||
* | 2006-06-02 Jay Monkman <jtm@lopingdog.com> | Jay Monkman | 2006-06-02 | 3 | -1/+18 |
| | | | | | * start/start.S, startup/linkcmds: Defined UNDEF exception stack space. | ||||
* | Regenerate. | Ralf Corsepius | 2006-01-14 | 1 | -1/+1 |
* | Regenerate. | Ralf Corsepius | 2006-01-12 | 1 | -0/+4 |
* | Remove all-local:. | Ralf Corsepius | 2006-01-12 | 1 | -2/+0 |
* | Regenerate. | Ralf Corsepius | 2006-01-12 | 1 | -1/+1 |
* | Cleanup. | Ralf Corsepius | 2006-01-12 | 1 | -2/+0 |
* | 2006-01-11 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-11 | 2 | -46/+6 |
| | | | | * Makefile.am: Add preinstall.am. | ||||
* | New. | Ralf Corsepius | 2006-01-11 | 1 | -0/+54 |
* | Cosmetics. | Ralf Corsepius | 2006-01-11 | 1 | -1/+0 |
* | 2005-11-22 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-11-22 | 2 | -7/+4 |
| | | | | * bsp_specs: remove %lib. | ||||
* | 2005-11-12 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-11-12 | 2 | -4/+4 |
| | | | | * bsp_specs: Remove %cpp. | ||||
* | 2005-05-26 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-05-26 | 2 | -3/+7 |
| | | | | * include/bsp.h: New header guard. | ||||
* | 2005-04-26 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2005-04-26 | 2 | -0/+5 |
| | | | | * network/network.c: Add include rtems/bspIo.h to eliminate warning. | ||||
* | Cosmetics. | Ralf Corsepius | 2005-01-28 | 1 | -2/+1 |
* | 2005-01-07 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-01-07 | 2 | -3/+7 |
| | | | | * Makefile.am: Eliminate CFLAGS_OPTIMIZE_V. | ||||
* | 2005-01-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2005-01-04 | 3 | -1/+6 |
| | | | | * startup/bspstart.c, startup/exit.c: Remove warnings. | ||||
* | 2005-01-02 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-01-02 | 2 | -57/+24 |
| | | | | * Makefile.am: Remove build-variant support. | ||||
* | 2004-11-05 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2004-11-05 | 2 | -4/+10 |
| | | | | | * startup/linkcmds: Add .gnu.linkonce.b section and account for memory area being named sdram NOT RAM. | ||||
* | Reformat. | Ralf Corsepius | 2004-10-26 | 1 | -11/+9 |
* | 2004-10-21 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-10-21 | 2 | -5/+9 |
| | | | | * startup/bspstart.c: Use POSIX fixed size types. | ||||
* | Fix typo in previous change. | Ralf Corsepius | 2004-09-24 | 1 | -1/+1 |
* | 2004-09-24 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-09-24 | 2 | -1/+5 |
| | | | | * configure.ac: Require automake > 1.9. | ||||
* | 2004-07-24 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2004-07-24 | 2 | -0/+18 |
| | | | | * .cvsignore: New file. | ||||
* | 2004-07-15 Jay Monkman | Jay Monkman | 2004-07-15 | 6 | -0/+68 |
| | | | | | * console/.cvsignore, include/.cvsignore, network/.cvsignore, start/.cvsignore, startup/.cvsignore: New files. | ||||
* | 2004-07-15 Jay Monkman | Jay Monkman | 2004-07-15 | 17 | -0/+2652 |
* ChangeLog, Makefile.am, README, bsp_specs, configure.ac, times, console/uart.c, include/bsp.h, include/tm27.h, network/lan91c11x.c, network/lan91c11x.h, network/network.c, start/start.S, startup/bspstart.c, startup/exit.c, startup/linkcmds, startup/memmap.c: New files. |
