CSB336 i.MX1/i.MXS memory map organization
- SDRAM starts at address 0x08000000 but 2 MB are reserved
for boot-block/loader (or other use) before RTEMS image
origin/load address (that is kept from previous setup)
- Caching of 30 MB of SDRAM used for RTEMS (start at 0x08200000)
is changed to writeback mode which provides higher throughput.
- The first 1 MB of RTEMS dedicated SDRAM is remapped to address 0
to provide area for ARM CPU exceptions table.
- Internal registers and rest of the Flash (above 1 MB) are mapped
one to one. Registers region is extended to 2 MB to cover
eSRAM found on i.MX1 chip variant.
- The first two megabytes of SDRAM unused by RTEMS are mapped
with attributes to allow specific purposes.
- the first MB (at address 0x08000000) is nocached to allow
directly set some values read by booot-block after warm reset
- the second MB (at address 0x08100000) is set for write-through
caching. That allows to use memory for LCD frame-buffer without
need to flush cache after each redraw.
Jump to start provided at address 0x08200000 allows
to load application image even as plain binary file
and start it by jump to image start address.
Signed-off-by: Pavel Pisa <ppisa@pikron.com>
XXX
* bsp_specs, start/start.S, startup/linkcmds: Use linker command base
file.
* console/uart.c: Eliminate warnings.
* start/start.S: Verify boot_card() is passed NULL.
* start/start.S: Update for boot_card command line change.
* include/bsp.h, network/lan91c11x.c, network/lan91c11x.h,
network/network.c, start/start.S, startup/bspstart.c, startup/exit.c,
startup/linkcmds, startup/memmap.c: Correct license URL and/or fix
mistake in copyright notice. Both of these mistakes appear to be from
code submitted after these changes were made previously.
* start/start.S, startup/linkcmds: Defined UNDEF exception
stack space.
* console/.cvsignore, include/.cvsignore, network/.cvsignore,
start/.cvsignore, startup/.cvsignore: New files.
* ChangeLog, Makefile.am, README, bsp_specs, configure.ac, times,
console/uart.c, include/bsp.h, include/tm27.h, network/lan91c11x.c,
network/lan91c11x.h, network/network.c, start/start.S,
startup/bspstart.c, startup/exit.c, startup/linkcmds,
startup/memmap.c: New files.
