Many files had an extra blank line in the license text
found in the file header. This patch removes that line.
* The license and distribution terms for this file may be
* found in the file LICENSE in this distribution or at
* http://www.rtems.com/license/LICENSE.
The script that did this also turned off execute permission
when it was turned on incorrectly.
* include/bsp.h, network/lan91c11x.c, network/lan91c11x.h,
network/network.c, start/start.S, startup/bspstart.c, startup/exit.c,
startup/linkcmds, startup/memmap.c: Correct license URL and/or fix
mistake in copyright notice. Both of these mistakes appear to be from
code submitted after these changes were made previously.
* ChangeLog, Makefile.am, README, bsp_specs, configure.ac, times,
console/uart.c, include/bsp.h, include/tm27.h, network/lan91c11x.c,
network/lan91c11x.h, network/network.c, start/start.S,
startup/bspstart.c, startup/exit.c, startup/linkcmds,
startup/memmap.c: New files.
