* | arm/beagle: Add per-section compilation and linking support | Aun-Ali Zaidi | 2016-01-09 | 1 | -0/+4 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | Both the BeagleBoards and the BeagleBones produce identical sized binaries. BeagleBoard Series ================== The size of the sample executables without this option were: text data bss dec hex filename 62616 1512 264177020 264241148 fbffffc minimum.exe 94228 1852 264145056 264241136 fbffff0 base_sp.exe 114556 1940 264124632 264241128 fbfffe8 nsecs.exe 191972 2328 264046828 264241128 fbfffe8 capture.exe 206412 1880 264032848 264241140 fbffff4 cdtest.exe 180680 2228 264058220 264241128 fbfffe8 paranoia.exe 107280 1716 264132132 264241128 fbfffe8 hello.exe 554392 5764 263680988 264241144 fbffff8 fileio.exe 97888 1852 264141396 264241136 fbffff0 ticker.exe 271728 6624 263962784 264241136 fbffff0 loopback.exe 593260 1984 263645896 264241140 fbffff4 cxx_iostream.exe 448400 12740 263779992 264241132 fbfffec pppd.exe 96224 1772 264143156 264241152 fc00000 unlimited.exe The size of the sample executables with this option enabled were: text data bss dec hex filename 30560 1212 264209364 264241136 fbffff0 minimum.exe 87656 1828 264151660 264241144 fbffff8 base_sp.exe 108076 1916 264131144 264241136 fbffff0 nsecs.exe 183540 2296 264055292 264241128 fbfffe8 capture.exe 197908 1856 264041384 264241148 fbffffc cdtest.exe 173976 2204 264064956 264241136 fbffff0 paranoia.exe 99752 1684 264139692 264241128 fbfffe8 hello.exe 537888 5740 263697524 264241152 fc00000 fileio.exe 91312 1828 264148004 264241144 fbffff8 ticker.exe 251360 6512 263983256 264241128 fbfffe8 loopback.exe 416176 1952 263823012 264241140 fbffff4 cxx_iostream.exe 415312 12584 263813252 264241148 fbffffc pppd.exe 89068 1740 264150344 264241152 fc00000 unlimited.exe BeagleBone Series ================= The size of the sample executables without this option were: text data bss dec hex filename 62616 1512 264177020 264241148 fbffffc minimum.exe 94520 1932 264144700 264241152 fc00000 base_sp.exe 114844 2020 264124280 264241144 fbffff8 nsecs.exe 192260 2408 264046476 264241144 fbffff8 capture.exe 206708 1960 264032456 264241124 fbfffe4 cdtest.exe 180976 2308 264057860 264241144 fbffff8 paranoia.exe 107280 1716 264132132 264241128 fbfffe8 hello.exe 554688 5844 263680596 264241128 fbfffe8 fileio.exe 98180 1932 264141040 264241152 fc00000 ticker.exe 272016 6704 263962432 264241152 fc00000 loopback.exe 593260 1984 263645896 264241140 fbffff4 cxx_iostream.exe 448696 12820 263779632 264241148 fbffffc pppd.exe 96224 1772 264143156 264241152 fc00000 unlimited.exe The size of the sample executables with this option enabled were: text data bss dec hex filename 30560 1212 264209364 264241136 fbffff0 minimum.exe 87944 1908 264151276 264241128 fbfffe8 base_sp.exe 108364 1996 264130792 264241152 fc00000 nsecs.exe 183828 2376 264054940 264241144 fbffff8 capture.exe 198196 1936 264041000 264241132 fbfffec cdtest.exe 174264 2284 264064604 264241152 fc00000 paranoia.exe 99752 1684 264139692 264241128 fbfffe8 hello.exe 538176 5820 263697140 264241136 fbffff0 fileio.exe 91600 1908 264147620 264241128 fbfffe8 ticker.exe 251648 6592 263982904 264241144 fbffff8 loopback.exe 416176 1952 263823012 264241140 fbffff4 cxx_iostream.exe 415600 12664 263812868 264241132 fbfffec pppd.exe 89068 1740 264150344 264241152 fc00000 unlimited.exe | ||||
* | BSP for several Beagle products | Ben Gras | 2014-11-03 | 4 | -4/+7 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | Specifically the beagleboard, beagleboard xM, beaglebone, beaglebone black. More info on these targets: http://www.beagleboard.org/ This commit forms a basic BSP by combining Claas's work with . new clock and irq code and definitions for beagle targets (beagleboard and beaglebones), mostly reused from the Minix codebase, thus making irqs, ticks and non-polled console mode work too . new timer code for ns timing with high timer resolution, 24MHz on the AM335X and 13MHz on the DM37XX . select the console uart based on target at configure time . removing all the lpc32xx-specific macros and code and other unused code and definitions that the beagle bsp was based on . re-using some standard functions instead of lpc32xx versions . fixed some whitespace problem in preinstall.am . fixed some compile warnings . configure MMU: set 1MB sections directly in the TTBR, just to show the difference between cacheable RAM and non-cacheable device memory and invalid ranges; this lets us turn on caches and not rely on boot loader MMU configuration. Verified to work when MMU is initially either on or off when RTEMS gets control. Thanks for testing, commentary, improvements and fixes to Chris Johns, Brandon Matthews, Matt Carberry, Romain Bornet, AZ technology and others. Signed-Off-By: Ben Gras <beng@shrike-systems.com> | ||||
* | Added BeagleBoard BSP | Claas Ziemke | 2014-11-03 | 2 | -0/+16 |
Coding done in course of GSoC2012. Commit edited to be brought up-to-date with mainline by Ben Gras <beng@shrike-systems.com>. |
