path: root/c/src/lib/libbsp/arm/beagle/irq.c (follow)
* am335x irq handling improvementMartin Galvan2016-02-281-40/+42
| | | | | | | | | | | | | This patch makes the following changes to the Beaglebone IRQ handling code: - Disable support for nested interrupts. - Detect spurious IRQs using the SPURIOUSIRQ field of the INTC_SIR_IRQ register. - Acknowledge spurious IRQs by setting the NewIRQAgr bit of the INTC_CONTROL register. This cleans the SPURIOUSIRQ field and allows new interrupts to be generated. - Improve the get_mir_reg function a bit. Closes #2580.
* Replace www.rtems.com with www.rtems.orgSebastian Huber2015-03-201-1/+1
* bsp/beagle: Fix some warningsBen Gras2014-12-151-1/+1
| | | | | | | The extra includes in console_*.c are to solve a 'no previous prototype' warning. Solves #2212 in trac.
* BSP for several Beagle productsBen Gras2014-11-031-0/+142
Specifically the beagleboard, beagleboard xM, beaglebone, beaglebone black. More info on these targets: http://www.beagleboard.org/ This commit forms a basic BSP by combining Claas's work with . new clock and irq code and definitions for beagle targets (beagleboard and beaglebones), mostly reused from the Minix codebase, thus making irqs, ticks and non-polled console mode work too . new timer code for ns timing with high timer resolution, 24MHz on the AM335X and 13MHz on the DM37XX . select the console uart based on target at configure time . removing all the lpc32xx-specific macros and code and other unused code and definitions that the beagle bsp was based on . re-using some standard functions instead of lpc32xx versions . fixed some whitespace problem in preinstall.am . fixed some compile warnings . configure MMU: set 1MB sections directly in the TTBR, just to show the difference between cacheable RAM and non-cacheable device memory and invalid ranges; this lets us turn on caches and not rely on boot loader MMU configuration. Verified to work when MMU is initially either on or off when RTEMS gets control. Thanks for testing, commentary, improvements and fixes to Chris Johns, Brandon Matthews, Matt Carberry, Romain Bornet, AZ technology and others. Signed-Off-By: Ben Gras <beng@shrike-systems.com>
