* | bsp/atsam: Use normal memory for QSPI flash area | Alexander Krutwig | 2016-09-16 | 1 | -2/+2 |
| | | | | This is a performance improvement for execute-in-place (XIP). | ||||
* | bsp/atsam: Move ram init values to structure. | Christian Mauderer | 2016-09-07 | 2 | -0/+23 |
* | atsam: Use normal memory for DTCM | Alexander Krutwig | 2016-07-26 | 1 | -0/+1 |
| | | | | Avoids problems with unaligned data access. | ||||
* | bsp/atsam: Add support for TCM | Alexander Krutwig | 2016-06-29 | 1 | -0/+2 |
* | bsp/atsam: Add nocache region support | Sebastian Huber | 2016-03-31 | 1 | -0/+1 |
* | bsp/atsam: Port SAM Software Package to RTEMS | Sebastian Huber | 2016-01-19 | 6 | -2/+97 |
| | | | | Update #2529. | ||||
* | bsp/atsam: Import SAM Software Package | Sebastian Huber | 2016-01-19 | 34 | -0/+4866 |
Import selected files of the "SAM V71 / V70 / E70 / S70 Software Package" obtained from the "SAMV71-XULT GNU Software Package 1.5". Converted files via dos2unix before import. Update #2529. |
