* startup/bspstart.c: Convert to using c99 fixed size types.
* Makefile.am: Reflect changes to bsp.am.
Preinstall dist_project_lib*.
* Makefile.am: Use CPPASCOMPILE instead of CCASCOMPILE.
* start/start.S, startup/libcfunc.c, startup/syscalls.c:
Include bspopts.h for ARM_RDI_MONITOR.
start/Makefile.am, startup/Makefile.am,
timer/Makefile.am, wrapup/Makefile.am. Use automake compilation rules.
* clock/Makefile.am, console/Makefile.am,
wrapup/Makefile.am: Remove.
* start/Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES.
* startup/Makefile.am: Ditto.
* wrapup/Makefile.am: Eliminate $(LIB).
Use noinst_DATA to trigger building libbsp.a.
* bsp_specs: Remove *lib:.
* console/console-io.c, include/bsp.h, startup/bspstart.c: URL for
license changed.
* startup/linkcmds: Add FreeBSD SYSCTL() sections for networking.
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
* startup/Makefile.am: Added -DARM_RDI_MONITOR.
Add bsplib_DATA = $(PROJECT_RELEASE)/lib/start$(LIB_VARIANT).o
(Didn't make it into cvs at 2002-07-20 :( )
* start/Makefile.am: Remove leftover from eliminating PGM.
* start/start.S: Added SWI_Handler.
* wrapup/Makefile.am: Add $(LIB) to all-local.
* startup/linkcmds: In support of gcc 3.1, added one of more
of the sections .jcr, .rodata*, .data.*, .gnu.linkonce.s2.*,
.gnu.linkonce.sb2.*, and .gnu.linkonce.s.*. Spacing corrections
and direction of segments to memory regions may also have been
addressed. This was a sweep across all BSPs.
