* console/console-io.c: Include rtems/bspIo.h instead of bspIo.h.
* configure.ac: Add RTEMS_BSPOPTS_*(ARM_RDP_MONITOR).
* startup/Makefile.am: Remove ARM_RDP_MONITOR, AM_CPPFLAGS.
* configure.ac: Add RTEMS_BPSOPTS_* for ARM_RDI_MONITOR.
* timer: New subdirectory.
* timer/Makefile.am: New file.
* timer/.cvsignore: New file.
* Makefile.am: Modified to reflect above.
* configure.ac: Ditto.
* console/console-io.c: Fixed typo.
* configure.in: Remove.
* configure.in: Add include/bspopts.h.
* console/Makefile.am: Use *_HEADERS instead of *H_FILES.
* irq/Makefile.am: Use *_HEADER instead of *H_FILES.
* include/.cvsignore: Add bspopts.h*, coverhd.h, stamp-h*
* include/Makefile.am: Add bspopts.h, Use *_HEADER instead of *H_FILES.
* include/bsp.h: Add bspopts.h.
* configure.in: Reworked for Canadian Cross support.
* config.guess, config.sub: Update from subversions.gnu.org.
* README.cdn-X: New file.
* tools/Makefile.am: Remove build, tools from SUBDIRS.
* console/console-io.c: Added console_initialize_hardware().
* startup/bspstart.c: Removed unused variables ramSpace and _end.
Added prototype for initialize_monitor_handles().
* startup/syscalls.c: Added casts and removed unused variables to
eliminate warnings.
* bsp_specs: Remove -Tlinkcmds from *link rule.
* bsp_specs, console/Makefile.am, include/Makefile.am: Clean up.
startup/Makefile.am, wrapup/Makefile.am: Include compile.am
