Add bsplib_DATA = $(PROJECT_RELEASE)/lib/start$(LIB_VARIANT).o
(Didn't make it into cvs at 2002-07-20 :( )
* start/Makefile.am: Remove leftover from eliminating PGM.
* start/start.S: Added SWI_Handler.
startup/Makefile.am, wrapup/Makefile.am: Include compile.am
