* armulator/.cvsignore, armulator/ChangeLog, armulator/Makefile.am,
armulator/bsp_specs, armulator/configure.ac, armulator/preinstall.am,
armulator/clock/clockdrv.c, armulator/console/console-io.c,
armulator/console/mon-syscalls.S, armulator/include/.cvsignore,
armulator/include/bsp.h, armulator/include/tm27.h,
armulator/start/start.S, armulator/startup/bspstart.c,
armulator/startup/libcfunc.c, armulator/startup/linkcmds,
armulator/startup/swi.h, armulator/startup/syscalls.c,
armulator/startup/trap.S: Removed.
* Makefile.am: Add abort.rel since it is now in the BSP shared source
-- not in score/cpu.
* Makefile.am: Merge c_rtems_main() into boot_card(). This eliminated a
file and simplified initialization.
* Makefile.am: Remove superfluous -DASM.
* Makefile.am: Add preinstall.am.
* Makefile.am: Eliminate CFLAGS_OPTIMIZE_V.
* Makefile.am: Remove build-variant support.
PR 610/bsps
* Makefile.am: Add include/tm27.h, Cosmetics.
* include/tm27.h: Final cosmetics.
* Makefile.am: Reflect changes to bsp.am.
Preinstall dist_project_lib*.
* Makefile.am: Use CPPASCOMPILE instead of CCASCOMPILE.
start/Makefile.am, startup/Makefile.am,
timer/Makefile.am, wrapup/Makefile.am. Use automake compilation rules.
* clock/Makefile.am, console/Makefile.am,
wrapup/Makefile.am: Remove.
* timer: New subdirectory.
* timer/Makefile.am: New file.
* timer/.cvsignore: New file.
* Makefile.am: Modified to reflect above.
* configure.ac: Ditto.
startup/Makefile.am, wrapup/Makefile.am: Include compile.am
that converts the i960 directory to automake.
The same kind of libbsp configuration as for the mips64orion, now for
the i960.
In addition to libbsp configuration this patch also contains two fixes
for cvme961.cfg and rxgen960.cfg, which contained non-functional
make-exes. (Now both bsps probably have the same issues with linking c++
applications as the gensh2 has, but this is a different open issue not
tried to be solved now).
The rxgen961 also seems to have problems with its start file, because
linking apps fails due to not finding start.o. (Note that
libbsp/i960/rxgen960 lacks a start subdirectory!). I leave solving this
issue to you :)
that converts the no_cpu directory to automake.
that converts nearly all of libbsp/sh to automake. Comments follow:
1. Almost full automake support for the libbsp/sh/ subdirectories
(exception libbsp/sh/gensh*/wrapup/*)
2. Fixes for libbsp/bare/*
3. Updates to libbsp/* configuration which supports old (autoconf/deep
configuration) and new (automake/flat/cascaded configuration) style
configuration of libbsp/<cpu>/*
