* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
* startup/Makefile.am: Added -DARM_RDI_MONITOR.
Add bsplib_DATA = $(PROJECT_RELEASE)/lib/start$(LIB_VARIANT).o
(Didn't make it into cvs at 2002-07-20 :( )
* start/Makefile.am: Remove leftover from eliminating PGM.
* start/start.S: Added SWI_Handler.
* wrapup/Makefile.am: Add $(LIB) to all-local.
* startup/linkcmds: In support of gcc 3.1, added one of more
of the sections .jcr, .rodata*, .data.*, .gnu.linkonce.s2.*,
.gnu.linkonce.sb2.*, and .gnu.linkonce.s.*. Spacing corrections
and direction of segments to memory regions may also have been
addressed. This was a sweep across all BSPs.
* console/console-io.c: Include rtems/bspIo.h instead of bspIo.h.
* configure.ac: Add RTEMS_BSPOPTS_*(ARM_RDP_MONITOR).
* startup/Makefile.am: Remove ARM_RDP_MONITOR, AM_CPPFLAGS.
* configure.ac: Add RTEMS_BPSOPTS_* for ARM_RDI_MONITOR.
* timer: New subdirectory.
* timer/Makefile.am: New file.
* timer/.cvsignore: New file.
* Makefile.am: Modified to reflect above.
* configure.ac: Ditto.
* console/console-io.c: Fixed typo.
* configure.in: Remove.
* configure.in: Add include/bspopts.h.
* console/Makefile.am: Use *_HEADERS instead of *H_FILES.
* irq/Makefile.am: Use *_HEADER instead of *H_FILES.
* include/.cvsignore: Add bspopts.h*, coverhd.h, stamp-h*
* include/Makefile.am: Add bspopts.h, Use *_HEADER instead of *H_FILES.
* include/bsp.h: Add bspopts.h.
* console/console-io.c: Added console_initialize_hardware().
* startup/bspstart.c: Removed unused variables ramSpace and _end.
Added prototype for initialize_monitor_handles().
* startup/syscalls.c: Added casts and removed unused variables to
eliminate warnings.
* bsp_specs, console/Makefile.am, include/Makefile.am: Clean up.
startup/Makefile.am, wrapup/Makefile.am: Include compile.am
