* Makefile.am: Reflect changes to bsp.am.
* Makefile.am: Use CPPASCOMPILE instead of CCASCOMPILE.
* Makefile.am: Pickup files from ../../arm/shared instead of
../shared. Reformat.
irq/Makefile.am, start/Makefile.am, startup/Makefile.am,
timer/Makefile.am, wrapup/Makefile.am. Use automake compilation rules.
* clock/Makefile.am, console/Makefile.am, irq/Makefile.am,
wrapup/Makefile.am: Remove.
* irq/Makefile.am: Ditto.
* start/Makefile.am: Ditto.
* startup/Makefile.am: Ditto.
* wrapup/Makefile.am: Eliminate $(LIB).
Use noinst_DATA to trigger building libbsp.a.
* startup/linkcmds: Remove SEARCH_DIR.
* irq/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* console/Makefile.am: Misc cleanups and fixes.
* irq/Makefile.am: Misc cleanups and fixes.
* console/Makefile.am: Remove all: $(ARCH).
* irq/Makefile.am: Remove all: $(ARCH).
* startup/Makefile.am: Remove all: $(ARCH).
* wrapup/Makefile.am: Remove all: $(ARCH).
* irq/Makefile.am: Add preinstallation dirstamp support.
* Makefile.am: Remove refs to non-existing files include/bspio.h and
include/uart.h.
* bsp_specs: Remove *lib:.
* include/bsp.h, include/registers.h, irq/bsp_irq_asm.S,
irq/bsp_irq_init.c, irq/irq.c, irq/irq.h, start/start.S,
startup/bspstart.c, startup/exit.c: URL for license changed.
irq/Makefile.am: Reflect having moved automake.
* startup/Makefile.am: Remove USE_INIT_FINI.
* bsp_specs: Remove -DUSE_ENHANCED_INTR_API.
* startup/linkcmds: Add FreeBSD SYSCTL() sections for networking.
* irq/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
* irq/Makefile.am: Use .$(OBJEXT) instead of .o.
* irq/bsp_irq_asm.S: Disable code to touch PIC.
* startup/linkcmds: In support of gcc 3.1, added one of more
of the sections .jcr, .rodata*, .data.*, .gnu.linkonce.s2.*,
.gnu.linkonce.sb2.*, and .gnu.linkonce.s.*. Spacing corrections
and direction of segments to memory regions may also have been
addressed. This was a sweep across all BSPs.
* configure.ac: Update, remove code rott.
* startup/exit.c: Include rtems/bspIo.h instead of bspIo.h.
