* arm_bare_bsp/.cvsignore, arm_bare_bsp/ChangeLog,
arm_bare_bsp/Makefile.am, arm_bare_bsp/bsp_specs,
arm_bare_bsp/configure.ac, arm_bare_bsp/clock/clockdrv.c,
arm_bare_bsp/include/.cvsignore, arm_bare_bsp/include/bsp.h,
arm_bare_bsp/include/registers.h, arm_bare_bsp/include/tm27.h,
arm_bare_bsp/irq/bsp_irq_asm.S, arm_bare_bsp/irq/bsp_irq_init.c,
arm_bare_bsp/irq/irq.c, arm_bare_bsp/irq/irq.h,
arm_bare_bsp/start/start.S, arm_bare_bsp/startup/bspstart.c,
arm_bare_bsp/startup/exit.c, arm_bare_bsp/startup/linkcmds: Removed.
irq/Makefile.am, start/Makefile.am, startup/Makefile.am,
timer/Makefile.am, wrapup/Makefile.am. Use automake compilation rules.
* clock/Makefile.am, console/Makefile.am, irq/Makefile.am,
wrapup/Makefile.am: Remove.
Reflect changes to bsp.am.
* configure.ac: Update, remove code rott.
* timer: New subdirectory.
* timer/Makefile.am: New file.
* timer/.cvsignore: New file.
* Makefile.am: Modified to reflect above.
* configure.ac: Ditto.
* wrapup/Makefile.am: Ditto.
* include/bsp.h: Stubs to let tm27 compile and link.
* configure.in: Remove.
