Closes #3611.
Create the Xen BSP for Xen on ARM.
Modifications to get xilinx-zynqmp BSP working on an Ultra96 board.
Update #3682.
Update #3090.
Close #2529.
updates #2451.
updates #2449.
updates #2450.
Coding done in course of GSoC2012.
Commit edited to be brought up-to-date with mainline by
Ben Gras <beng@shrike-systems.com>.
Implemented so far:
- nocache heap for uncached RAM
- basic timer
- level 1 cache handling for arm cache controller
in arm-cache-l1.h
- level 2 L2C-310 cache controller
- MMU
- DWMAC 1000 ethernet controller
- basic errata handling
- smp startup for second core
* acinclude.m4: Added lm3s69xx BSP.
* acinclude.m4: Add BSP for GDB ARM simulator so we can easily
experiment with and debug different ARM architectural variations.
* acinclude.m4: New Gumstix BSP.
* acinclude.m4: New BSP -- lpc24xx.
* acinclude.m4, shared/comm/console.c: Use standardized bsp_cleanup()
which can optionally print a message, poll for user to press key, and
call bsp_reset(). Using this eliminates the various bsp_cleanup()
implementations which had their own implementation and variety of
string constants.
shared/startup/linkcmds.base, shared/include/linker-symbols.h, shared/include/start.h, shared/start/start.S: New files.
* acinclude.m4: Add smdk2410. Update gp32 to use shared code.
* acinclude.m4: Adding Nintendo DS BSP.
* acinclude.m4: Remove armulator.
* acinclude.m4: Regenerate.
* acinclude.m4: Added GBA BSP.
* acinclude.m4: Removed vegaplus BSP.
* vegaplus/.cvsignore, vegaplus/ChangeLog, vegaplus/Makefile.am,
vegaplus/bsp_specs, vegaplus/configure.ac, vegaplus/clock/clockdrv.c,
vegaplus/include/.cvsignore, vegaplus/include/bsp.h,
vegaplus/include/registers.h, vegaplus/include/tm27.h,
vegaplus/irq/bsp_irq_asm.S, vegaplus/irq/bsp_irq_init.c,
vegaplus/irq/irq.c, vegaplus/irq/irq.h, vegaplus/start/start.S,
vegaplus/startup/bspstart.c, vegaplus/startup/exit.c,
vegaplus/startup/linkcmds: Removed.
* acinclude.m4: Added gp32 BSP.
* gp32/.cvsignore, gp32/Makefile.am, gp32/README, gp32/bsp_specs,
gp32/configure.ac, gp32/console/.cvsignore, gp32/console/conio.c,
gp32/console/console.c, gp32/console/defaultfont.c,
gp32/include/.cvsignore, gp32/include/bsp.h, gp32/include/conio.h,
gp32/include/tm27.h, gp32/start/.cvsignore, gp32/start/start.S,
gp32/startup/.cvsignore, gp32/startup/bspstart.c,
gp32/startup/exit.c, gp32/startup/linkcmds, gp32/startup/memmap.c: New files.
* acinclude.m4: Added csb336 and csb337 BSPs
* acinclude.m4: Reflect changes to bootstrap.
* configure.ac: Remove RTEMS_CHECK_CUSTON_BSP.
* acinclude.m4: Added edb7312.
* acinclude.m4: New file.
