Update #3285.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
* preinstall.am, shared/lpc/include/lpc-i2s.h,
shared/startup/linkcmds.armv4, shared/startup/linkcmds.armv7: New
files.
* Makefile.am: Added header and linker command files intended to be
used by every ARM BSP.
* shared/startup/linkcmds.base: Support for EABI and ARM ELF standard.
* shared/include/linker-symbols.h: Update due to linker command file
changes.
* shared/start/start.S, shared/include/start.h: Renamed entry symbol
from start to _start to avoid namespace conflicts. Update due to
linker command file changes.
* shared/irq_init.c: Removed file.
* Makefile.am: Reflect change above.
* shared/comm/console.c: Remove (Unused).
* Makefile.am: Remove shared/comm/console.c.
* Makefile.am: Add abort.rel since it is now in the BSP shared source,
not in score/cpu.
* Makefile.am: Use @RTEMS_BSP_FAMILY@ instead of
$(RTEMS_BSP_FAMILY).
* Makefile.am, shared/Makefile.am, shared/comm/Makefile.am,
shared/irq/Makefile.am: Include compile.am
