* armulator/.cvsignore, armulator/ChangeLog, armulator/Makefile.am,
armulator/bsp_specs, armulator/configure.ac, armulator/preinstall.am,
armulator/clock/clockdrv.c, armulator/console/console-io.c,
armulator/console/mon-syscalls.S, armulator/include/.cvsignore,
armulator/include/bsp.h, armulator/include/tm27.h,
armulator/start/start.S, armulator/startup/bspstart.c,
armulator/startup/libcfunc.c, armulator/startup/linkcmds,
armulator/startup/swi.h, armulator/startup/syscalls.c,
armulator/startup/trap.S: Removed.
* shared/abort/abort.c, shared/abort/simple_abort.c: New files.
* Makefile.am: Add abort.rel since it is now in the BSP shared source,
not in score/cpu.
* acinclude.m4: Regenerate.
* shared/irq/irq_init.c: Remove unused var.
* shared/irq/irq_init.c: Changed interrupt handling
to use shared rtems_irq_connect_data struct.
* Makefile.am: Merge-in shared/Makefile.am.
* ChangeLog: Merge-in shared/ChangeLog.
* configure.ac: Remove shared/Makefile.am.
* acinclude.m4: Added GBA BSP.
* acinclude.m4: Removed vegaplus BSP.
* vegaplus/.cvsignore, vegaplus/ChangeLog, vegaplus/Makefile.am,
vegaplus/bsp_specs, vegaplus/configure.ac, vegaplus/clock/clockdrv.c,
vegaplus/include/.cvsignore, vegaplus/include/bsp.h,
vegaplus/include/registers.h, vegaplus/include/tm27.h,
vegaplus/irq/bsp_irq_asm.S, vegaplus/irq/bsp_irq_init.c,
vegaplus/irq/irq.c, vegaplus/irq/irq.h, vegaplus/start/start.S,
vegaplus/startup/bspstart.c, vegaplus/startup/exit.c,
vegaplus/startup/linkcmds: Removed.
* acinclude.m4: Added gp32 BSP.
* gp32/.cvsignore, gp32/Makefile.am, gp32/README, gp32/bsp_specs,
gp32/configure.ac, gp32/console/.cvsignore, gp32/console/conio.c,
gp32/console/console.c, gp32/console/defaultfont.c,
gp32/include/.cvsignore, gp32/include/bsp.h, gp32/include/conio.h,
gp32/include/tm27.h, gp32/start/.cvsignore, gp32/start/start.S,
gp32/startup/.cvsignore, gp32/startup/bspstart.c,
gp32/startup/exit.c, gp32/startup/linkcmds, gp32/startup/memmap.c: New files.
* acinclude.m4: Remove arm_bare_bsp.
PR bsps/771
* configure.ac: Remove reference to arm_bare_bsp in
AC_CONFIG_SRCDIR. Use ../arm instead.
* arm_bare_bsp/.cvsignore, arm_bare_bsp/ChangeLog,
arm_bare_bsp/Makefile.am, arm_bare_bsp/bsp_specs,
arm_bare_bsp/configure.ac, arm_bare_bsp/clock/clockdrv.c,
arm_bare_bsp/include/.cvsignore, arm_bare_bsp/include/bsp.h,
arm_bare_bsp/include/registers.h, arm_bare_bsp/include/tm27.h,
arm_bare_bsp/irq/bsp_irq_asm.S, arm_bare_bsp/irq/bsp_irq_init.c,
arm_bare_bsp/irq/irq.c, arm_bare_bsp/irq/irq.h,
arm_bare_bsp/start/start.S, arm_bare_bsp/startup/bspstart.c,
arm_bare_bsp/startup/exit.c, arm_bare_bsp/startup/linkcmds: Removed.
* acinclude.m4: Added csb336 and csb337 BSPs
* configure.ac: RTEMS_CHECK_BSPDIR([$RTEMS_BSP_FAMILY]).
* Makefile.am: Use @RTEMS_BSP_FAMILY@ instead of
$(RTEMS_BSP_FAMILY).
* configure.ac: Remove shared/comm/Makefile, shared/irq/Makefile.
* acinclude.m4: Reflect changes to bootstrap.
* configure.ac: Remove RTEMS_CHECK_CUSTON_BSP.
PR 480/bsps
* shared/irq/irq_asm.S: Remove duplicate code.
* acinclude.m4: Added edb7312.
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
* configure.in: Remove.
* acinclude.m4: New file.
* configure.in: remove shared/io/Makefile.
* bsp_specs: Remove -Tlinkcmds from *link rule.
* Makefile.am, shared/Makefile.am, shared/comm/Makefile.am,
shared/irq/Makefile.am: Include compile.am
