* acinclude.m4: Add BSP for GDB ARM simulator so we can easily
experiment with and debug different ARM architectural variations.
* shared/comm/console.c: Reflect termios_baud_to_number having been
renamed to rtems_termios_baud_to_number.
Added bsp_start_memcpy(). Documentation. Changes for external ROM start.
* acinclude.m4: New Gumstix BSP.
* shared/start/start.S: Update for boot_card command line change.
PR 1385/cpukit
* shared/irq/irq_asm.S: When the type rtems_boolean was switched to the
C99 bool, the size changed from 4 bytes to 1 byte. The interrupt
dispatching code accesses two boolean variables for scheduling
purposes and the assembly implementations of this code did not get
updated.
* shared/irq/irq_asm.S: Newer compilers handle alignment better.
* Makefile.am, configure.ac, preinstall.am: Added BSP variants.
* console/console-config.c, clock/clock-config.c, ssp/ssp.c: Fixed
register settings. Cleanup.
* include/bsp.h: Added network defines and functions.
* include/lpc24xx.h: Added AHB and EMC defines. Fixed Ethernet status
sizes.
* include/system-clocks.h, misc/system-clocks.c: Added micro seconds
delay function that uses Timer 1. Changed PLL setup.
* network/network.c, startup/bspreset.c, startup/linkcmds.lpc2478,
startup/linkcmds.lpc2478_ncs, startup/linkcmds.lpc2478_ncs_ram: New
files.
* startup/bspstart.c: Added EMC initialization. Changes for ROM boot.
* acinclude.m4: New BSP -- lpc24xx.
* acinclude.m4, shared/comm/console.c: Use standardized bsp_cleanup()
which can optionally print a message, poll for user to press key, and
call bsp_reset(). Using this eliminates the various bsp_cleanup()
implementations which had their own implementation and variety of
string constants.
shared/startup/linkcmds.base, shared/include/linker-symbols.h, shared/include/start.h, shared/start/start.S: New files.
* shared/bspgetworkarea.c: Removed.
* shared/bspgetworkarea.c: New file.
* shared/irq/irq_init.c: Add missing prototypes.
* shared/irq/irq_asm.S: Correct minor mistakes in adding Thumb code
which prevented ARM from working.
* shared/comm/console.c: Eliminate copies of switches to convert
termios Bxxx constants to xxx as an integer. Use the shared
termios_baud_to_number() routine to do the same conversion.
* csb336/startup/bspstart.c, csb337/startup/bspstart.c,
edb7312/startup/bspstart.c, gba/startup/bspstart.c,
gp32/startup/bspstart.c, rtl22xx/startup/bspstart.c: Add capability
for bootcard.c BSP Initialization Framework to ask the BSP where it
has memory for the RTEMS Workspace and C Program Heap. These
collectively are referred to as work area. If the BSP supports this,
then it does not have to include code to split the available memory
between the two areas. This reduces the amount of code in the BSP
specific bspstart.c file. Additionally, the shared framework can
initialize the C Library, call rtems_debug_enable(), and dirty the
work area memory. Until most/all BSPs support this new capability, if
the BSP supports this, it should call
RTEMS_BSP_BOOTCARD_HANDLES_RAM_ALLOCATION from its configure.ac. When
the transition is complete, this autoconf macro can be removed.
* acinclude.m4: Add smdk2410. Update gp32 to use shared code.
* acinclude.m4: Adding Nintendo DS BSP.
* shared/comm/console.c: Do not have BSP specific __assert.
* shared/abort/simple_abort.c: Add veneer for ARM<->Thumb
shared/irq/irq_asm.S: Add veneer for ARM<->Thumb
* gba/irq/irq.c: test for non-NULL-ness before calling
'on'/'off' methods so that users don't have to provide
no-ops if they don't want this feature.
PR 1257/bsps
* csb336/network/lan91c11x.c, csb337/startup/bspstart.c,
edb7312/irq/irq.c, gba/irq/irq.c, gba/irq/irq_init.c,
gp32/startup/bspstart.c, rtl22xx/startup/bspstart.c,
shared/abort/abort.c, shared/abort/simple_abort.c,
shared/irq/irq_init.c: Code outside of cpukit should use the public
API for rtems_interrupt_disable/rtems_interrupt_enable. By bypassing
the public API and directly accessing _CPU_ISR_Disable and
_CPU_ISR_Enable, they were bypassing the compiler memory barrier
directive which could lead to problems. This patch also changes the
type of the variable passed into these routines and addresses minor
style issues.
* shared/abort/abort.c, shared/abort/simple_abort.c: Remove incorrect
and unneccessary prototype of printk.
* shared/abort/simple_abort.c: Shrink the memory requirements. Joel
reformatted for style.
* acinclude.m4: Remove armulator.
* armulator/.cvsignore, armulator/ChangeLog, armulator/Makefile.am,
armulator/bsp_specs, armulator/configure.ac, armulator/preinstall.am,
armulator/clock/clockdrv.c, armulator/console/console-io.c,
armulator/console/mon-syscalls.S, armulator/include/.cvsignore,
armulator/include/bsp.h, armulator/include/tm27.h,
armulator/start/start.S, armulator/startup/bspstart.c,
armulator/startup/libcfunc.c, armulator/startup/linkcmds,
armulator/startup/swi.h, armulator/startup/syscalls.c,
armulator/startup/trap.S: Removed.
* shared/abort/abort.c, shared/abort/simple_abort.c: New files.
* Makefile.am: Add abort.rel since it is now in the BSP shared source,
not in score/cpu.
* acinclude.m4: Regenerate.
* shared/irq/irq_init.c: Remove unused var.
* shared/irq/irq_init.c: Changed interrupt handling
to use shared rtems_irq_connect_data struct.
* Makefile.am: Merge-in shared/Makefile.am.
* ChangeLog: Merge-in shared/ChangeLog.
* configure.ac: Remove shared/Makefile.am.
* acinclude.m4: Added GBA BSP.
* acinclude.m4: Removed vegaplus BSP.
* vegaplus/.cvsignore, vegaplus/ChangeLog, vegaplus/Makefile.am,
vegaplus/bsp_specs, vegaplus/configure.ac, vegaplus/clock/clockdrv.c,
vegaplus/include/.cvsignore, vegaplus/include/bsp.h,
vegaplus/include/registers.h, vegaplus/include/tm27.h,
vegaplus/irq/bsp_irq_asm.S, vegaplus/irq/bsp_irq_init.c,
vegaplus/irq/irq.c, vegaplus/irq/irq.h, vegaplus/start/start.S,
vegaplus/startup/bspstart.c, vegaplus/startup/exit.c,
vegaplus/startup/linkcmds: Removed.
* acinclude.m4: Added gp32 BSP.
* gp32/.cvsignore, gp32/Makefile.am, gp32/README, gp32/bsp_specs,
gp32/configure.ac, gp32/console/.cvsignore, gp32/console/conio.c,
gp32/console/console.c, gp32/console/defaultfont.c,
gp32/include/.cvsignore, gp32/include/bsp.h, gp32/include/conio.h,
gp32/include/tm27.h, gp32/start/.cvsignore, gp32/start/start.S,
gp32/startup/.cvsignore, gp32/startup/bspstart.c,
gp32/startup/exit.c, gp32/startup/linkcmds, gp32/startup/memmap.c: New files.
* acinclude.m4: Remove arm_bare_bsp.
PR bsps/771
* configure.ac: Remove reference to arm_bare_bsp in
AC_CONFIG_SRCDIR. Use ../arm instead.
* arm_bare_bsp/.cvsignore, arm_bare_bsp/ChangeLog,
arm_bare_bsp/Makefile.am, arm_bare_bsp/bsp_specs,
arm_bare_bsp/configure.ac, arm_bare_bsp/clock/clockdrv.c,
arm_bare_bsp/include/.cvsignore, arm_bare_bsp/include/bsp.h,
arm_bare_bsp/include/registers.h, arm_bare_bsp/include/tm27.h,
arm_bare_bsp/irq/bsp_irq_asm.S, arm_bare_bsp/irq/bsp_irq_init.c,
arm_bare_bsp/irq/irq.c, arm_bare_bsp/irq/irq.h,
arm_bare_bsp/start/start.S, arm_bare_bsp/startup/bspstart.c,
arm_bare_bsp/startup/exit.c, arm_bare_bsp/startup/linkcmds: Removed.
* acinclude.m4: Added csb336 and csb337 BSPs
* configure.ac: RTEMS_CHECK_BSPDIR([$RTEMS_BSP_FAMILY]).
* Makefile.am: Use @RTEMS_BSP_FAMILY@ instead of
$(RTEMS_BSP_FAMILY).
