2003-09-15 | 2003-09-15 Jay Monkman <jtm@smoothsmoothie.com> | Jennifer Averett | 1 | -0/+5 | |
PR 480/bsps * shared/irq/irq_asm.S: Remove duplicate code. | |||||
2003-08-18 | 2003-08-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+4 | |
* Makefile.am: Reflect having moved aclocal/. | |||||
2003-08-18 | Fix broken ChangeLog entries. | Ralf Corsepius | 1 | -1/+1 | |
2003-08-16 | 2003-08-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+4 | |
Makefile.am: Reflect having moved automake. | |||||
2003-08-11 | 2003-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+4 | |
* configure.ac: Use rtems-bugs@rtems.com as bug report email address. | |||||
2003-03-11 | Merger from rtems-4-6-branch. | Ralf Corsepius | 1 | -0/+4 | |
2003-02-11 | 2003-02-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+4 | |
* configure.ac: AM_INIT_AUTOMAKE([1.7.2]). | |||||
* configure.ac: AC_PREREQ(2.57). | |||||
2002-12-06 | 2002-12-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+4 | |
* configure.ac: Remove RTEMS_CHECK_BSP_CACHE. | |||||
2002-11-13 | 2002-11-13 Jay Monkman <jtm@smoothsmoothie.com> | Joel Sherrill | 1 | -0/+4 | |
* acinclude.m4: Added edb7312. | |||||
2002-10-21 | 2002-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+6 | |
* .cvsignore: Reformat. Add autom4te*cache. Remove autom4te.cache. | |||||
2002-03-28 | 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1 | -0/+7 | |
* configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * Makefile.am: Remove AUTOMAKE_OPTIONS. | |||||
2001-10-11 | 2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1 | -0/+6 | |
* .cvsignore: Add autom4te.cache for autoconf > 2.52. * configure.in: Remove. * configure.ac: New file, generated from configure.in by autoupdate. | |||||
2001-10-10 | 2001-10-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1 | -0/+5 | |
* acinclude.m4: New file. * configure.in: Use RTEMS_BSP_SUBDIR. | |||||
2001-05-24 | 2001-05-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1 | -0/+4 | |
* configure.in: remove shared/io/Makefile. | |||||
2000-11-09 | 2000-11-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1 | -0/+4 | |
* Makefile.am: Use ... instead of RTEMS_TOPdir in ACLOCAL_AMFLAGS. | |||||
2000-11-02 | 2000-11-02 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -0/+4 | |
* bsp_specs: Remove -Tlinkcmds from *link rule. | |||||
2000-11-02 | 2000-11-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1 | -0/+4 | |
* Makefile.am: Switch to ACLOCAL_AMFLAGS = -I $(RTEMS_TOPdir)/aclocal. | |||||
2000-10-27 | 2000-10-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1 | -0/+5 | |
* Makefile.am: ACLOCAL_AMFLAGS= -I $(RTEMS_TOPdir)/macros. Switch to GNU canonicalization. | |||||
2000-09-05 | 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1 | -0/+5 | |
* Makefile.am, shared/Makefile.am, shared/comm/Makefile.am, shared/irq/Makefile.am: Include compile.am | |||||
2000-08-10 | Adding ChangeLogs. | Joel Sherrill | 1 | -0/+3 | |
